Unknown diodes
  • lti
    • May 2011
    • 2547
    Unknown diodes
    I want to know what the three diodes on this board are. If it's hard to see in the picture, D1 and D2 are marked W1 and D3 is marked 4D. I've found some 2.4V zener diodes marked W1, but these two diodes are being used as half-wave rectifiers in a 2.4V battery charger (D1 provides an AC detection signal for the IC). They're obviously not zener diodes.
    If anyone is wondering, this board came from a toothbrush. I took apart the same model of toothbrush a few years ago, and it had worn motor brushes. This one also has a dead motor, but it took out Q1 (TDM2306), which is kind of impressive for something that runs from two 300mAh 1/2AA NiCd cells. I'm going to disassemble the motor because there is a position where I measure a short across the terminals.
  • ReverendJones
    Resurgam
    • May 2010
    • 49
    Re: Unknown diodes
    W1 FES3A Si-diode Ultrafast Recovery, 50V, 3A, <50ns
    4D MMSZ2V7 Z-diode 2.7V±5%, Izt=5mA, Zzt=100, 500mW
    Info is from the Turuta SMD-Codes Databook, 2011 Edition.
    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
      • 30979
      Re: Unknown diodes
      i have that book, it also id's them as something else - a bit of a problem without drawing a schematic.
      • lti
        • May 2011
        • 2547
        Re: Unknown diodes
        I think I found the W1 diode. It's a 1N4448W made by Semtech.
        http://www.semtech.com.hk/script/pro...1421443877.pdf
        There might be other diodes in the same package (SOD-123) with the same markings, but this makes sense. I have an older revision of this board (from the other toothbrush) that uses small MELF package diodes like 1N4148s. On the older board, D3 is a larger through hole glass diode.
        If it helps, VE+ is the battery positive, VE- is the battery negative, and MTR+ and MTR- are the motor connections.
          • 30979
          Re: Unknown diodes
          those in the foto look a bit big for a 4448
          • lti
            • May 2011
            • 2547
            Re: Unknown diodes
            They're the same package shown in the datasheet.
            I'll have to test the diode at D3 to see if it is a zener. The diode on the older board is marked C2V7, but it doesn't appear to be a 2.7V zener diode. That diode is in parallel with the motor.
            • lti
              • May 2011
              • 2547
              Re: Unknown diodes
              D3 is a 2.7V zener diode on both boards. It is most likely the MMSZ2V7 that ReverendJones mentioned, but there is also an MM1Z2V7 from the same manufacturer (EIC) with slightly better tolerances. The through-hole diode on the other board may be a BZX79-C2V7 or a similar part from a company nobody has heard of.
                Re: Unknown diodes
                D3, C1 are just snubbers to protect Q1 from back EMF from the motor.
                Q1 drives (low side (sink) the load which is the Motor) the motor but if the motor has really low DCR, then lots of current will try to flow through Q1 and burnt it up.
                Did you remove D3, C1 to verify if they are not shorted without motor in place?
                • lti
                  • May 2011
                  • 2547
                  Re: Unknown diodes
                  I didn't think the little battery could continuously supply enough current to make that FET fail open. There is voltage at the gate (slightly lower than the battery voltage, as expected with the voltage divider formed by R4 and R9) when the motor should be running, so the IC is still working properly. D3 and C1 are not shorted. I tested that diode earlier to see if it was a zener or a normal diode. Rotating the motor shaft made the resistance increase to 5 ohms.
                  One of the motor brushes was bent and touching the wrong contacts. It looks like the brush wore down so far that it got caught in between contacts on the commutator and bent. The motor is similar to a Mabuchi FA-130RA.
                  I noticed that there is a plus sign molded into the plastic near one terminal. If that means that the motor should only turn in one direction (battery positive to the terminal with the plus sign next to it), then it was being used with the polarity reversed.
                  • fuhz2009
                    • Dec 2012
                    • CHINA
                    Re: Unknown diodes
                    Thanks for share this info.
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • sbt123
                      charnwood w821 mini wood lathe motor problem
                      by sbt123
                      hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                      10-27-2024, 03:43 AM
                      Aquarius WaterPik WP-100W water flosser
                      by momaka
                      And for today's “Other Weird Devices” thread, let's have a look at an Aquarius WaterPik WP-100W water flosser. What is it? Apparently, it's kind of a power washer, of sorts, for cleaning teeth & gums. Who knew these existed, right?
                      A family friend asked me to take a look at their older one, since it stopped powering On. So let's have a look at what went wrong.
                      First, a view of the box (note: it's from a newer model) and the device itself:
                      ^ Is it me, or does anyone else find it a little humorous how the box says it's “ADA Accepted”? ...
                      09-29-2021, 09:26 PM
                    • Srdjan01
                      Oral-B IO Series 6
                      by Srdjan01
                      Hi everybody.
                      I'm trying to fix this toothbrush that doesn't wanna start. And I need your help.
                      Just to inform you that I'm supperbeginner
                      First photos are from internet because I did not took a photo of whole board.
                      I have noticed that fuse marked with "E" near the battery pole is bad and decided to short it with a "proper calibrated wire" as one would say.
                      Now, when I apply 1V from the power supply, limited to 500mA, one of the component stick out from the rosin mist. CHC N2AB (or some variation of that letters) is the hottest...
                      03-05-2025, 10:05 AM
                    • Per Hansson
                      Motor run capacitor physical size vs voltage rating & measurements?
                      by Per Hansson
                      (TL;DR skip the first paragraph)
                      I encountered my first dead motor run capacitor at a customer this week.
                      For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                      (Unless a servo motor makes more sense that is).
                      But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                      The pump would run but sometimes trip the 10A breaker.
                      I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                      Then it could...
                      09-20-2020, 06:32 AM
