Car battery charger - faulty
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Had a bit of a mishap with a car battery charger today, some magic smoke when I plugged it in.
    So I opened it up, and it's a fairly straightforward unit, a transformer, 2 switches (12v/6v, Hi/Lo charge), a simple LED indicator for battery health and charging, a bridge rectifier and some type of device on the negative lead that goes to the battery being charged.
    The smoke was coming from the bridge rectifier, the casing is now a bit cracked. So i thought maybe a nice easy fix. But when I tested the switches (with BR disconnected), I found that there was continuity between all the switches, no matter what position each switch was in
    So I'm thinking there is a problem with the transformer. The outlet side of the transformer has 5 tabs, one connected to the negative of the BR, the other 4 wired to the switches, so I'm presuming these 4 are supplying the 12v/Hi, 12V/Lo, 6V/Hi, 6V/Lo. So with all wires disconnected from the transformer, I'm getting continuity between all 5 tabs.
    I presume this is not the way it should be? (I'm a bit clueless with transformers, dangerous yokes!)
    So, I suppose I'm wondering how this happened? I'm guessing the lamination on the windings has gone bad, but would that happen because the BR went bad?
    I did test the BR, and there is full continuity between 3 of the pins. I didn't really take notes because of the smoke and visual damage to it, but I know that continuity like that (out of circuit) isn't right. On the pin that didn't have continuity with the others, I think it was open on it one way, and showing 0.7 on a diode test, so one of the diodes inside may still be ok, but at least 2 others probably not.
    Or maybe the transformer went bad first, sending (12V x2) + (6V x2) at 10+ amps, and that's what cooked the BR? What would cause the transformer to go bad? Could a 3 foot drop onto tarmac cause it to go bad? Or if the positive and negative battery clamps were connected for a short time, could that cause the windings to bake off the lamination?
    Very grateful for any insight. I need to understand more about transformers.
  • tw2005
    • Oct 2011
    • 6458
    Re: Car battery charger - faulty
    It will be a multi tapped transformer, and I would read up a bit just to improve your knowledge but essientially a winding which has pick off points and I would expect the result you had.
    Start with some good photos of the design. The cracked/smoking rectifier is probably a good place to start for replacement.
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks for the link. It looks like I should expect continuity between the pick-off points after all. I do need to read up more about them. I was thinking that there were discrete windings for each of the voltage outs.
      I'll check the resistance between the points tomorrow. I took some photos, but also drew the circuit, I found that helped me understand more about the circuit.
      I'll see about getting a replacement BR82, I doubt I have any in the stash. The charger is probably 15+ years old, would be nice if that was all that was wrong with it.
      Is it safe to connect the transformer to the AC, and test the voltage on the outlet (secondary?) side between the lead going to the BR negative, and each of the other 4 tabs?
      Should the multimeter be set to VAC when doing this test?
        The DC resistance of the transformer windings will be very low, you have to use Ringer tester to find out if it has shorted turn or not, using Ohm meter to test transformer will only show if it has open winding, shorts between windings, but not for shorted turns.
        Show us the pictures of the unit.
        "Or maybe the transformer went bad first, sending (12V x2) + (6V x2) at 10+ amps" transformer does not actually sending the 10A current, the load will determine how much current it wants to draw from the transformer and if the transformer and the circuit will be able to supply the current demand or not.
        To understand it better is to draw the path of the current flow from the source to the load and return back to the source.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          For power transformers, if you disconnect the secondary and only power the primary, if the transformer gets warm/hot when it didn't when it was new, it has shorts winding in it...
          But just like any other high voltage circuit testing... it's dangerous! One hand rule/isolation transformers/etc. all apply.
          However I kind of doubt winding failure happened. Make sure that primary and secondary are still isolated - if this is ok, then most likely I don't think the transformer is faulty enough to damage the rectifier. Quite possibly the output was shorted and someone kept it on for a period of time, cooking the bridge...
          Or perhaps the switch broke and shorted everything together?
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            The switches test ok after I disconnect them from the transformer.
            There is the possibility the battery leads were touching when power was applied, not today when I first noticed the smoke, but when it was elsewhere. My rule is generally connect the battery leads, make sure the switches are in the correct positions, plug into mains, switch mains on.
            There is something in-line on one of the battery leads, not sure what it is, maybe a thermal overload, or one-way current device? I'll have another look later, I don't have it here right now.
            The photos I took were with a camera phone, just for quick noting of where the wires are going. I'll take and post some decent photos later tomorrow.
            Thanks for the replies.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5086
              • New Zealand
              Bridge rectifiers sometimes just short and blow up for fun, too.
              If you used diode\continuity test on the transformer you will get false readings, as already mentioned.
              -David VanHorn
              • tmcw
                • Oct 2010
                • 382
                • Ireland
                I did the AC test on the 4 outlet taps, and I'm getting 5.90v-6.50v on two, and about 11.80v-12.50v on the other 2, so it looks like the transformer is ok.
                I was reading a discussion elsewhere, and they were saying that that sort of variance for a car charger was fine, the battery can handle the fluctuation, and hence why they don't use smoothing caps in these designs.
                I'll post a few photos later, for anyone who's interested.
                The BR is a BR86. Might be a few weeks before I can get a replacement, but I'll update when/if I get it replaced and repaired.
                • tmcw
                  • Oct 2010
                  • 382
                  • Ireland
                  I was having a quick look for a replacement, and it seems the BR86 might be a less used number now.
                  Would the 806 I see mentioned more commonly, be an equivalent part?
                  http://www.ebay.co.uk/sch/i.html?_od...0v+8a&_sacat=0
                  http://ie.rs-online.com/web/p/bridge...fiers/8172617/
                  http://ie.rs-online.com/web/p/bridge...fiers/2278586/
                  The specs seem to be similar, though I can't compare them all.
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    BU1508-E3/45
                    any with a current of 8A or greater and voltage 20volts or greater will work
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                      "I was reading a discussion elsewhere, and they were saying that that sort of variance for a car charger was fine, the battery can handle the fluctuation, and hence why they don't use smoothing caps in these designs" It is positive pulse charging (no filter cap), if it is full wave rectifier then the pulse will be 120 Hz (100 Hz for 50 Hz power), half wave will be 60 Hz (50 Hz).
                      • tmcw
                        • Oct 2010
                        • 382
                        • Ireland
                        I found a S10VB60 in an exotic power supply.
                        It's rated at 600V and 10A (original was 600V and 8A). As far as I can tell, it's rated the same or slightly better for most of the parameters that I can compare from the datasheets I've seen for both. Same package type as well.
                        So until I get a direct replacement, I might give this one a shot.
                        Edit: I've attached a poor photo of the unit. The bridge rectifier is to the bottom left side (brown wire attached, so directly to the left of the circuit board). The heatsink the bridge rectifier was attached to it at the top-left, a metal plate that runs about three quarters the length of the case. The Hi/Lo and 12V/6V switches are at the bottom (just above the label)
                        So a fairly simple unit: Mains inlet to top of transformer, secondary outlets to 12V/6V switch, then to Hi/Lo switch (with some loops to the circuit board for battery condition and charging status), next through the bridge rectifier, and from there to the leads that go onto the battery. I didn't figure out what the yoke on the negative battery lead is, it can be seen to the left of the transformer, it's insulated inside a thick plastic cylinder. One-way device, or thermal protection?
                        • tmcw
                          • Oct 2010
                          • 382
                          • Ireland
                          Doing a bit of additional searching, I found this page:
                          http://www.vetco.net/catalog/product...oducts_id=4408
                          It's a page for a bridge rectifier, but it lists equivalent replacements, of which my original BR86 (CP806) and the alternative S10VB60 I found a few hours ago are listed as replacements.
                          It got me wondering if there is a site where comparisons/equivalents for components (new and historical) can be easily determined. I know I can input specifications on some supply sites and get alternatives, but they might not list a component I might happen to have in my stash or on a board I need to check. Searching for and downloading a datasheet isn't such a big deal, but if there was a useful page like the one linked above, where I could make a quick determination whether a component was equivalent or not, it would greatly help finding replacement parts.
                            • 31283
                            most of us would just go to farnell or whatever supplier we use and put in the minimum voltage & current and see what they have.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5086
                              • New Zealand
                              I can't be sure from the photo, but that thing on the negative lead looks like it might just be a wire joiner of some kind.
                              Don't worry about the bridge rectifier too much, as long as it can hande the voltage and current, that's about all you need to care about with it, especially at low frequencies like the mains.
                              -David VanHorn
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                I would think about putting a inline fuses in the output circuit so if you touch the two leads together again you will only have to replace the fuse. Perhaps a fuse like one in a car that you just pull . They have holders that can be solder right in line with the output leads.
                                • motormayhem
                                  Lenovo T460 Only Charges on One Charger
                                  by motormayhem
                                  Laptop Question
                                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                  05-12-2023, 01:46 PM
                                • flat-earther
                                  how to prevent a connected charger from draining battery when not charging?
                                  by flat-earther
                                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                  So the battery is backfeeding the charger and being drained.
                                  How can I prevent...
                                  08-07-2025, 01:04 PM
                                • flat-earther
                                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                                  by flat-earther
                                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                  Windows also shows ''Plugged in'' when charger is not connected.
                                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                  If I let battery run out and say it has 3% Windows will...
                                  06-24-2025, 09:32 AM
                                • Phil289
                                  Battery Charger - Transformer advice
                                  by Phil289
                                  Hi
                                  (not sure if this is the right place to post this but couldnt see anywhere else)
                                  I Have a very old battery charger which was given to me - it is 6v/12v 10amp.
                                  It is in like new condition and even in the origonal box - it works fine but is very noisey (buzzing)
                                  It buzzes as soon as its turned on even with no load on it.
                                  It appears to be the transformer thats making the noise.
                                  Can anything be done apart from find a new transformer?
                                  (Have attached a picture and a small video of the noise)
                                  Thanks...
                                  08-01-2022, 01:43 PM
                                • learnmore
                                  Help choosing replacement transformer for Levoit 600S SMPS
                                  by learnmore
                                  Hello Community,
                                  I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                  Peace
                                  LM...
                                  11-04-2025, 09:35 AM
