Power Adapter that will replace 3 AA batteries
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    I have a Petlinks toy that has 3 AA batteries it runs on. I have tries to use a Panasonic EB-CA340 AC adapter to replace the batteries which has failed. The supply is 5.6 Volts at 400 ma. I have tried the supply by itself. It lights the on light of the pet toy, but then goes out. I tried a various voltage divider circuits 4.6 volts and 5.3 volts. I have used both high resistance voltage dividers and low resistance dividers with the same result. I even used a computer power supply at 5.3 volts. The computer supply did not even light the on light. All the time I used these supplies I monitor the voltage with a multimeter and the voltage stayed the same as the open circuit voltage. I even tried to put a micro and milli amp meter in series with the three AA batteries but the toy would not turn on. I wonder if someone out there knows of a adapter the will emulate the characteristic of three AA batteries in series? I do not want to have to built a linear adapter I was hoping that their already is one on the market. I have been unable to find one on the internet nor are the full specifications supplied with one one's on the internet.
    Re: Power Adapter that will replace 3 AA batteries
    May be they also tap part of the batteries connection to get lower Voltage beside the 4.5V of the total output. You need to look at the batteries holder to see if it has two wires from the batt holder.
    "Panasonic EB-CA340" is this linear power supply wallwart or regulated output? If it is non regulated linear then the out put will be much higher (around 8V) than 5.6V without full load of 400mA which could have damaged the circuit..
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      It only has two wires. One going to the neg.terminal and one from going to the positive terminal. The three AA batteries are in series. The only information I have is that the adapter is made by I.T.E. for a Panasonic Cell Phone. I.T.E says all their adapters are regulated and that seems right because I did not see a change in voltage. Linear is a funny word. The places that sell power supplies or wallwarts use linear to represent non-switching supplies. My understanding is all wallwarts from about 2002 are switching. Also, the circuit is not damaged as when I replace the batteries it works fine. The internal resistance of a AA battery is about 0.2 ohms at room temperature. The only thing I can think off is this engineer is going a ERS measurement before he starts the program.
        Did you check the current draw, especially at start up when it works with AAA?
        There are still lots of Linear (unregulated and regulated) power supply out there. the Linear lasts much longer than the SMPS type but it uses more power and not green due to power consumption in standby mode, vampire power.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Yea, I tried to check the current draw but the device would not operate with the meter inline. I figure if I put the linear adapter under a switch receptacle and only use it when the cat wanted to play it would not be quite a Vampire. I can not find any spec online that would tell me if these supplies are not switching. Do you know where I might get a non switching adapter that is 4.5 volts without having to make one?
            • 31281
            4.5v - rings a bell, a door bell.
            go look for a bell transformer.
            or get a variable supply, you can get wall bricks with a switch: 3v, 4.5v, 6v, 9v, 12v
              "Yea, I tried to check the current draw but the device would not operate with the meter inline." More likely that the fuse for the over current protection in your meter is blown.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                "I even tried to put a micro and milli amp meter in series with the three AA batteries but the toy would not turn on."
                Use the 10A DC range, the current you tried to measure is too high for the milliamp range.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  We are talking about 3 AA batteries if the current was around 10 Amps the toy would not run over 12 minutes. These batteries life expectancy are rated somewhere around 2200 mah. That is 2.2 amps in one hour.
                    If the fuse for the current protection is blown, it will explain why the toy does not work when you put the meter in series with batteries.
                    My Fluke 87 has two fuses for current ranges, one is only 400mA, another one is 10A.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Yea, your right it is blown. I thought the milliamp rating of my meter went to 1.0 Amp but it only goes to, they say 400 ma, but it is fused for 500ma. This must be the start up current because I can't see operating at 500ma. It would only last 4.5 hours. It still does not explain why the computer supply did not operate the toy. The other adapter had a current rating for 400 ma. So I can see why that one did not work. I will now connect the Amp meter back using the 10 A setting. Thank Guys.
                        If it has dc motor, the inrush current can be easily be 10 times the running current (Applied Voltage divided by Armature resistance = Ia).
                        http://www.electrical4u.com/starting...e-of-dc-motor/
                        You meter has to be fast enough to catch the inrush, my Fluke has Peak hold reading and can capture 1mSec Pulse.
                        So we know it draws more than 0.5A for sure since the fuse blown.
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          I was able to measure the running current. When on first turns on it is on slowest speed. That I=0.460 A so the resistance is 9.82 ohms because the running voltage is 4.56 volts down from 4.60 Open circuit voltage. Which is about 0.046 ohms internal resistance of the batteries. They are lithium 1.5 volt. The ATX supply still will not drive this using the 5 Volts that measured 5.3 volts. It says its I rating is 32 Amps at that voltage. That is the only thing the supply is driving. So, maybe a linear Adapter that has 5 Amps of current, if inrush is 10 times the amount?
                          Sounds more like a power supply than an adapter.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            I believe the motor is a stepper motor because it is able to turn directions at the drop of a hat, so it must be getting pulsed. Is far as the a hold setting on this meter I do not see any DC current freq specification,only AC current frequency specs. and the DC pulse width is measured in voltage +5V to 0V. Some of this stuff is coming back to me communicating with you guys. It has been 20 years since I did circuit analysis and 35 years since I graduated College.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              BudM I was just able to click on your link. Seems like an awesome sight for teaching. This will refreshing my memory. Thank you.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                BudM I was able to find a power supply schematic for a stepper motor from the site you so kindly shared. It will take me a while to get all the parts and look up the specs so I can supply the 5 volts. I have to get the right transformer, bridge diodes etc. It looks like using a TIP 2955 to sink the in rush current will work.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  I decided not to build the supply because the cat got bored with the toy and only likes me moving the feather on a stick so it would be wasted to make a power supply, but thanks guys for your support.
                                  • Mcfeetroy
                                    Fishing bite alarm drains battery
                                    by Mcfeetroy
                                    Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                    08-01-2025, 03:52 AM
                                  • carrzkiss
                                    Cyberpower cps1500avr not charging batteries
                                    by carrzkiss
                                    Hello, all.
                                    Cyberpower Battery Backup Unit.
                                    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                    Checking the voltage, it was down to 22v.
                                    I quickly removed everything...
                                    06-15-2024, 02:10 PM
                                  • u666sa
                                    HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                    by u666sa
                                    Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                    Platform: ipa32 la-m024p rev 1b
                                    Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                    I found a short on the other side:
                                    10-04-2025, 05:03 PM
                                  • howardc64
                                    Where do repair shops buy MB replacement batteries?
                                    by howardc64
                                    Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                    Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                    BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                    07-25-2024, 10:42 AM
                                  • Astonished
                                    Fixing the Charge Circuit of the Batteries of the DC Motor
                                    by Astonished
                                    Hi friends of electronics
                                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                    Please help me fix this circuit.
                                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                                    01-28-2025, 06:24 AM
