3-wire meter help
  • davmax
    • Dec 2005
    • 899
    Re: 3-wire meter help
    If there is no neutral the voltage coil is not operating, no connected circuit that I can see from your diagram. Attached Jpg. Should read " There is NO voltage connect for the top coil"
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
    • pentium
      • Mar 2006
      • 2778
      Can I carry this on tomorrow?
      I am dead tired and it's making me have trouble reading your diagrams.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • starfury1
        • May 2006
        • 1256
        Again this is of no direct help
        (as in, put this wire there etc, which I know is really what your after)
        Well Seems there are more ways to skin a cat depending on how you may actually be hooked up and what type of meter.
        (see 3 wire connections here)
        http://themeterguy.com/
        A run down on the meter and a single Active hookup
        (as in probably the way you had it wired)
        here
        3 wire setups Here
        (note how the coils are represented for the A B N)
        basically deals in the modern type and I could find no reference to the old ones.
        for ref here is the 2 wire single phase Here
        I don't understand exactly what the schematic representation is of in the circle..I would be guessing so no comment from me on that or the mention of form 1 2 etc, except its maybe the meter construction?
        Like I said no electrician here
        Thanks Davmax for your input.
        I sent this before Id finished it but anyway
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • davmax
          • Dec 2005
          • 899
          Pentium. I hope you have had enough sleep now. I would agree that some elctrical guy who actual has connection experience is your ideal source, but there seems to be no offers.
          What puzzles me about your meter.
          1. To change from 240V to 120V either the voltage coil must be tapped with three wires (this does not appear to be the case) or the current coils have to be re-arranged (the only apparent option). Current coils either in series or parallel as per my diagrams.
          2. If the voltage coil remains at 120V for a 240V supply then error can arise if one phase goes missing.
          3. Where is the neutral connection?
          I am sure that you can make it work with what has been offered. One caution is that the phasing of the current coil with the voltage coil. Try with voltage coil and one current coil and see if there is a difference when the current coil connections are reversed. If there is a better response one way use that connection as a starting point.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • davmax
            • Dec 2005
            • 899
            See attached document
            Starfury1 sent me a PM with a 240V split system picture. The split system rather than phases is well understood. However the PM made it clear that the neutral in an external connection and that the wattmeter voltage coil may always requires 240VAC. ie the meter always has 2 splits connected. This means that when connecting 120VAC devices they will be attached to a current coil on one of two splits. Each 120V device load is returned to neutral externally. (same config as for 240 but the load is split with the centre to neutral)
            This method ensures that if one split voltage is missing there will be no meter error there will be simple zero meter operation, because the volts coil will have no current flow.
            If this is correct (it makes a lot of sense) then each current coil is rated for the heavier 120VAC load currents.
            Thanks for the input Starfury1
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • pentium
              • Mar 2006
              • 2778
              I agree with you there.
              First, I'm going to finish off the rest of my wiring before trying again. What I had setup was temporary and I need to make it permanant.
              Find Nedry!
              • starfury1
                • May 2006
                • 1256
                #27
                posting this mainly for those wondering how the American 3 wire single phase system works
                here is a couple of links....not to do with meter hook up but it does explain a bit on the American system towards the bottom.
                Single-phase power systems
                the discussion thread I found it in Here
                it does get into the bit were things become a bit grey with phase relationship or rather the confusion that stems from it.
                another tibit here
                my suspicion Davmax is the first one you draw above (2nd diagram post) is it
                but have nothing concrete technically to confirm or write it off as being totally wrong.
                you raised some questions I got to work through
                In short I dont know....at this point
                So I gotta think on it
                • davmax
                  • Dec 2005
                  • 899
                  #28
                  Thanks Starfury1. Your links confirm my second set of diagrams, last posted.I think we have it there.
                  It is now for Pentium to get connected and see how it goes.
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                  • starfury1
                    • May 2006
                    • 1256
                    #29
                    No worries Davmax
                    well that from what little I could find and make some kind of sense of, its probably it.
                    Pentium is dealing with a meter style and hookup no longer sold
                    (or standard not being used)
                    by the looks of it so unfortunately no accurate hook up information can I find.
                    sorry But your on your own there
                    You need to identify whats what with your meter and hook it up the right way
                    (Again I know what you really wanted was "the put this wire there" answer)
                    I think if the meter is S2 or Form 2 (whatever standard its called)
                    type he can use it, since Pentium said it was used in a 220V hookup.
                    (seems some meters are dual purpose, although there are some situations if used in 110V only monitoring it can be inaccurate.
                    somewhere, possibly in the links above I read it)
                    The meter from one comment I found says it all,
                    its an electric motor by any other name LOL.
                    Here, as I said... this is the Provence of "licensed Electricians"
                    so All disclaimers apply here legal and otherwise
                    You do at your own risk and we assume
                    what you are doing is legal in your state and meets your states regulations...
                    Any injuries deaths property damaged etc is your responsibility
                    we accept no responsibility for your actions
                    Cheers
                    • pentium
                      • Mar 2006
                      • 2778
                      I completed a better and more clearly marked diagram of the meter. I wull try to scan it in tomorrow I hope.
                      I'm going to also wait until my new 20A breaker is installed. Part of the problem that I am trying to go 3-wire through a single 120V line ( )
                      Call me stupid.
                      Find Nedry!
                      • starfury1
                        • May 2006
                        • 1256
                        #31
                        That put a whole different slant on it, the assumption was 240V with 2 Actives
                        As per the above 1 phase 3 wire
                        • starfury1
                          • May 2006
                          • 1256
                          #32
                          If you are branching a single 120V ac line and then trying to get the meter to monitor both branches I don't think it was designed for that...you would have to put it before the the split as per 120V hook up
                          (as I was thinking was the case before)
                          It might be doable but not really sure
                          "Do not" used the above hook 3 wire 240V, it won't work!
                          rethink time
                          • davmax
                            • Dec 2005
                            • 899
                            #33
                            The problem is that the meter is designed for 240VAC on voltage coil.
                            Could try 120V on coil and use one current coil. Theoretically you would get half the wattage reading because voltage coil field is half.
                            Nvidia 8500GT 256Mb
                            33 way card reader
                            Windows XP Pro SP3
                            • pentium
                              • Mar 2006
                              • 2778
                              Those two posts just sent our understanding back to square one.
                              Just let me do what I need to do here and let's start over again.
                              Find Nedry!
                              • starfury1
                                • May 2006
                                • 1256
                                #35
                                pentium did have the meter set up for 120 VAC operation and the meter can from what I understand do both.
                                The key is with the way you arrange the two current coils (I think)...I sort of remember reading something on that in relation to the maths ....that the two have to be setup in a particular setup for 120Vac so the meter reads accurately
                                I dont think he can do what he wants to do with it,
                                it wasn't designed to work that way
                                He may get it to work but it wouldn't be accurate.
                                I also remember reading something on under some conditions use of 120 VAC setup, can result in inaccurate measurement.
                                (what they were I can't recall)
                                He would have to put it in circuit before he branches the circuit and from what I gather the way he is planing to have the second circuit will not allow him to put the meter before the branch set up is done.
                                If you can pentium post a diagram (from the meter information that you got)
                                of exactly what the meter is suppose to be setup as for 120Vac KWH operation, if you can relate that back to the physical meter as well thats even better
                                You have to remember these were designed to monitor a houses "total consumption" the individual (branch) circuits would came after the meter
                                The "240 volt 3 wire hook up" will not help you in this instance if you are paralleling (branching) a single Active / Neutral 120 VAC (Earth) setup
                                It just wont work
                                (0 volts across voltage coil, since its the same Active)
                                BTW so we a clear on this, you are not building a "single phase 3 wire 240V"
                                setup
                                You are paralleling 2 120V VAC circuits
                                (to a common point, that common point must be suitably rated as per your rules and regs)
                                (since you mentioned 120VAC only)
                                yep your right back to square 1,
                                but I dont think you will be able to do want you want
                                Hope you Dont take this the wrong way pentium but I really think its a job for a licensed spark as to do want you want sounds like you got to go back to the board and have a meter put there.
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Will do.
                                  The "240 volt 3 wire hook up" will not help you in this instance if you are paralleling (branching) a single Active / Neutral 120 VAC (Earth) setup It just wont work
                                  Yeah, I biffed up there. The diagram will clear that up.
                                  BTW so we a clear on this, you are not building a "single phase 3 wire 240V" setup
                                  No.
                                  Both circuits must not get wired together in any way.
                                  One is rated 15 amps and is for the smaller systems, the second one is 20 amps and supplies power to my two deskside systems. wiring them together would be a really bad thing.
                                  I am just exploiting the 3-wire configuration to meter two individual circuits and not one circuit.
                                  Shoot. Gotta go. Bell.
                                  Find Nedry!
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Okay, I was cut off befor I could finish that last sentence so I'll say it again.
                                    No.
                                    Since split-phase is made from +120v, neutral and -120v all that is needed to do to make two individual 120v circuits is to tie together the neutral wires (reduces stress on the wire) and in the place of the +120v connection you put the hot lead for one circuit and in the place of the -120v connection you put the hot lead for the other circuit.
                                    If my theory is right, one mwter will then tell me how much power TWO individual circuits are consuming.
                                    I will post that sketch soon. I need to get to the scanner.
                                    Find Nedry!
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Here's the sketch I made. I also color-coded the wires.
                                      Find Nedry!
                                      • starfury1
                                        • May 2006
                                        • 1256
                                        #39
                                        Thanks for the diagram, it will help me understand how it was setup
                                        what I meant was at some point they will *tie together....from what you say it seems both circuits are individually being brought out from the box. that being the common point (box wiring).
                                        (*or to the individual Actives + or - in the split phase case)
                                        Sorry pentium I think your out of luck with what you what to as far as using it on both circuits unless you put a sub board in for those two circuits
                                        Just to cover this point here
                                        No.
                                        If my theory is right, one meter will then tell me how much power TWO individual circuits are consuming.
                                        The problem is for "single phase 3 wire 240 VAC setup it MUST be BOTH a RED and BLACK ACTIVE
                                        If you use say 2 RED actives...its the same thing so no voltage drop across voltage coil (active to active) of meter. Ditto black Active
                                        Doing what you saying if you use a 120V hook up (which uses the Neutral)
                                        tie the voltage coil across one Active to Neutral and use the 2 coils each in series with the single active line for 15 A, 20 A branches, it may work but would not run correctly.
                                        (apart from the fact its possibly illegal)
                                        As I said the meter is not designed to work (correctly) that way from what I understand
                                        even if it was a single phase 3 wire setup you would need to have a "common feed" to the meter "before" the circuits are branched off into there 15A 20A configuration.
                                        There is no way by the sounds of it that you are bringing them out from the box as a common feed...Thats why I said you would need to have a meter put in the box.
                                        Your only other alternative is 2 meters in 120VAC setup on each branch (leg) circuit which would probably need to go on a sub board panel anyway.
                                        (again I don't know what the legal aspects are to this either)
                                        The meter its self becomes part of the circuit so you just cant go running wires back to it from different places
                                        (anything like that I very much doubt would be legal, apart from inaccuracies that maybe generated)
                                        Given the age and style of the meter I doubt that you would be able to use it legally in a new setup...(I could be wrong)
                                        The setup must be done in accordance with your local wiring code or it would be deemed illegal
                                        If your house Burnes down and illegal wiring was found you would get no payout this is why everything has to meet your local electrical code and be inspected were inspection is required.
                                        it would be simpler if I could draw diagrams but I cant scan anything cause the new box doesn't have a parallel port and the scanner is parallel only.
                                        (got to sort that out)
                                        Maybe this book might help, unfortunately its like $90 US dollars
                                        you might see if your local library has it in their system.
                                        Handbook for Electricity Metering - Tenth Edition
                                        http://www.eei.org/products_and_serv...ok_meterng.htm
                                        It might help.
                                        really wish I could be of more help and give a you a positive out come.
                                        Cheers
                                        • davmax
                                          • Dec 2005
                                          • 899
                                          #40
                                          Pentium. You say that you are driving to seperate circuits/loads, one from each 120V split. That is how the meter is intended to operate, you are right on. This is the connection I last sent, and yes the power on both circuits will be measured correctly so long as the voltage coil is connected to 240V as per my diagram and yours of the meter. Neutral is external, the return for each split, neutral current is minimised by having each split current close to equal. Looks like your going to be successful.
                                          Nvidia 8500GT 256Mb
                                          33 way card reader
                                          Windows XP Pro SP3
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • SavaBogdan
                                            Help disabling a vcore phase on a MSI X570 Carbon - I have schematics + boardview
                                            by SavaBogdan
                                            Hello.
                                            Does anyone have any experience with disabling a power phase on the CPU vrm?
                                            The controller is IR35201 6+2 phases. It only uses 5 phases and the pins for pwm and feedback on the 6'th phase are not populated (no traces).
                                            I got the board with a burned mosfet which I removed along with a part of the pcb. I dremelled away the short as best I could and the board started up fine without the vrm heatsink.
                                            I then put some sealant and left it for two days to completely dry. I suspect the pressure from the thermal pads on the heatsink compressed the layers so when I started...
                                            10-21-2022, 10:05 AM
