555 blinking unit
  • wee wee
    • Aug 2013
    • 16
    • south africa
    555 blinking unit
    Hi Everyone,
    Sorry for the basic question...
    So I need to built a beacon light with LEDs. for the flashing unit I would like to use the 555 ic. But since I am not too good I just went to the electronic shop and asked :" I need to make a led blink, one sec on one sec off, please give me what i need for it i will then go use Google image to find the right scheme".
    .... now at home I am sitting with component that differ from everything i find on the Internet... maybe the vendor got confused.
    So here is what I have?
    1x 555 ic
    1x MOSFET
    1x capacitor 100 uf 1/4
    1x capacitor (witch only writing on it is "103" not even sure where the + side is...)
    So how do i connect those to make my led blink???
    Ready , set .... GO!!!! :p
    • 30964
    Re: 555 blinking unit
    example circuits are in the datasheet.
    • wee wee
      • Aug 2013
      • 16
      • south africa
      Hi STJ,
      Thanks for the quick reply,
      Can't find what I am looking for in that pdf, because I am not good enough I get confused everywhere.
      Can I even achieve my goal with those only component I got ?
        • 30964
        no.
        you need some resistors atleast to set the speed of the 555.
          Just do the search 'FLASHING LED USING 555' you will see lots of circuits.
          I.E.:
          http://rookieelectronics.com/555-tim...-flashing-led/
          http://www.ohmslawcalculator.com/555_astable.php
          http://www.bowdenshobbycircuits.info/555.htm
          • wee wee
            • Aug 2013
            • 16
            • south africa
            hi guys,
            Thx budm thanks for the nice links,
            I have tried to build this circuit;
            http://1.bp.blogspot.com/-CNBgqyD0uM...1600/555-1.png
            But it didn't work, I must have made a mistake somewhere...
            So went to do a simpler one:
            http://images.brighthub.com/f1/4/f14...022f8_orig.jpg
            The light comes on onces then off and thats it .... only one blink
            Tried again with this one
            Then same, only one blink
            I have used a 12v led... and put 10v input
            Still don't get what to do with the mosfet...
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Pin 3 out from the 555 IC will go to the Gate on the Mosfet while the +12V will connect in series with a bulb while the Source will go to Gnd. Therefore, the Mosfet will act like switch........
              • wee wee
                • Aug 2013
                • 16
                • south africa
                I will try that thanks,
                But most of the circuit I found don't have the mosfet so why would mine do that?
                  The 555 does not have high current drive, so you need transistor, MOSFET to source or sink the high current, or use relay.
                  If you are going to drive the lamp, the cold resistance can be 10 times lower than the HOT resistance so the current in rush will be very high.
                    http://www.williamson-labs.com/555_apps.htm
                    • wee wee
                      • Aug 2013
                      • 16
                      • south africa
                      Ok got it right with two transistor and a relay it works like a charm.
                      But now for an other project I need an LED dimmer. look like its gotta work with a 555 too.
                      I have built this two:
                      http://rcexplorer.se/diy/2010/02/led-photobuild-lights/
                      http://www.talkingelectronics.com/pr...LED-Dimmer.gif
                      But the led is blinking ??? after getting through all that trouble to get one to blink ....
                      I don't want it the blink just want to be able to dim it.
                      What did i got wrong in those circuit?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8688
                        Probably your capacitor is too big. The timing capacitor you have from pin 2 to GND needs to be 100 nanofarads and not something like 100 microfarads.
                          • 30964
                          that dimmer works by blinking the led very fast.
                          what are you actually making and why?
                          because there are other ways of dimming an led.
                          • wee wee
                            • Aug 2013
                            • 16
                            • south africa
                            What are those other way to dim a led??
                            Basically I have a three way switch that light up 3 red led on one side or two white leds in the other position. I want to put a potentiometer at the entry of that switch to dim the leds selected (either the white or the red one).
                            The two groups of led (3v) are in parallel with the adequate resistor (12v input) .
                            Can I get that right with just a potentiometer ?? a 10k?
                            • wee wee
                              • Aug 2013
                              • 16
                              • south africa
                              anyone ...
                                • 30964
                                led dimming is best done with a current regulator circuit.
                                pwm is not for beginners really.
                                *i* would use a pic microcontroller, but i can write the software for it and program it!
                                • cloo
                                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                  by cloo
                                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                  After doing a factory reset this problem was gone and the picture was back to...
                                  01-06-2025, 06:02 AM
                                • EazyBone
                                  Un50cu7000 2 blink oddity *partially solved
                                  by EazyBone
                                  I write this to maybe help another with this TV.
                                  So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                  The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                  03-18-2024, 10:24 PM
                                • ngml
                                  Repair of an LG split AC system indoor unit PCB
                                  by ngml
                                  I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                  This indicates an error in the communication between the outdoor and the indoor unit.
                                  The outdoor unit is fine, so the problem is the indoor PCB.
                                  The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                  I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                  Does anybody have the schematics of this board,...
                                  02-01-2025, 12:55 PM
                                • YasaCh
                                  Sony kdl 40p5500 red light keeps blinking 3 times
                                  by YasaCh
                                  Hello...
                                  my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                  i opened the back cover no sign of damage on the powery suply or motherboard
                                  when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                  another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                  07-07-2025, 11:53 AM
                                • Vebririon
                                  panasonic TX-P50V10E 6 blink led problem
                                  by Vebririon
                                  I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                  Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                  I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                  05-17-2025, 10:16 AM
