Way to dissolve the evil brown glue?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5008
    • New Zealand
    I have a ceramic capacitor that I wish to read the value of. I can't do this because it's covered in evil glue which is obscuring the markings. Also I do not trust the glue to not interfere with measuring it on a capacitance meter.
    Is there something I can dissolve the glue with that will hopefully not remove the paint from the capacitor as well?
    I normally scrape the glue off with a blade but that is not really an option here.
    -David VanHorn
  • mockingbird
    • Dec 2008
    • 5484
    Re: Way to dissolve the evil brown glue?
    My favorite "poor man's" solvent is charcoal starter fluid. You can also use kerosene in a pinch, but kerosene is a dirty hydrocarbon and the stench lingers.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      carb cleaner. or gasoline in a pinch.
      Follow the white rabbit.
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        Heat gun helps too.
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          For the corrosive glue Sansui used to use I remove it with acetone. It has taken the printing off of newer capacitors though. On the old Sansui's I really don't care because I'm in there to replace them anyway.
          sigpicThe Sky Is Falling
          • popeye
            • May 2011
            • 155
            heat it up to 120deg c it will just peel off then
              • 31143
              acetone or xylene.
              if you go xylene - do it outside, that stuff will damage your brain!!
              also, know that you can melt plastics and remove paint with these - you WILL take the stripes off resistors for example.
              i think most brake fluid is xylene based btw.
              if it smells sweet - you shouldnt be smelling it!!!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                brake fluid is typically glycol... xylene would be way too volatile/flammable for a high heat application such as brakes. But xylene is a great solvent - for nonpolar materials. Does nothing for water based material.
                A lot of the times the glue is chosen such that any solvent used will also dissolve the electronics underneath. Pretty much only mechanical removal is the only option, if heating it doesn't help.
                I would at least try carburetor cleaner, if you don't have VOC regulations near you, methylene chloride in the "cheap" formulation is a good solvent too, for nonpolar materials. Else acetone in the VOC regulated formula also works. Both these can eat some types of plastics.
                Need to determine what kind of glue it is - that's the underlying problem. I haven't found anything that dissolves set epoxy...
                  • 31143
                  my mistake, i meant brake / carb cleaner not fluid.
                    • 31143
                    gel paint stripper slowly desolves epoxy.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I got some brake cleaner and forgot if it was the low VOC formula or not. Seems it's mostly heptane and other non oxygenated organics. Yeah, might have had xylenes in it.
                      Might have to try some paint stripper or equivalent, looks like some are made of methylene chloride/dichloromethane too, or even sodium hydroxide (all of these are nasty). These can cause damage to the circuit which is the main reason why I haven't tried...
                        • 31143
                        how about MEK (methyl keytone) ?
                        another one for outside use.
                        • rhomanski
                          nowhere man
                          • 5157
                          • U S of A
                          If you use MEK, wear gloves. I've watched 5 people die from brain tumors from using it.
                          The first was my lead mechanic in 1991. He took a weeks vacation, I asked on Monday where he was and they said, "You didn't hear?". Words I began to dread over the years. He lost his peripheral vision and was dead a week later.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5008
                            • New Zealand
                            Originally posted by kasfamily
                            Heat gun helps too.
                            I decided to try this idea first as being the least messy and least likely to remove the paint as well. I used my hot air rework tool on lowest (160°C) and pulled the glue off with tweezers. Worked very well, no damage to the capacitor.
                            I heard the horror stories about MEK in high school. Wouldn't go near the stuff...
                            -David VanHorn
                            • Al-Umar
                              Need Help to dissolve glue
                              by Al-Umar
                              Please can someone tell me the chemical that can be apply to dissolve glue that used to hold the type C chip and SSD storage chip MacBook 2017 touchbar on the board.
                              Please i need a prescription of that chemical. i will be very glad if someone can help me out on that
                              05-04-2024, 07:46 AM
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • mitsu2k
                              The Real Dangers of conductive glue.
                              by mitsu2k
                              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                              Here is an experience I...
                              04-16-2023, 06:29 PM
                            • kalemaroni
                              Dell DC Brown wire
                              by kalemaroni
                              There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                              08-26-2025, 10:10 AM
                            • digtalhd
                              Remove IC glue
                              by digtalhd
                              Hi!
                              Anybody help me. Remove IC glue on mainboard.
                              Thank you....
                              11-08-2024, 02:25 AM
