Sony BluRay Player - Locks up
  • caphair
    • Nov 2011
    • 1249
    Model: BDP-S3100
    Will attempt to boot but gets stuck on logo screen. Sometimes it completes the cycle and I can power it on but it instantly freezes up again.
    I've tried holding down the stop button while booting as I read it resets the resolution and 3/5 times it'll load doing it that way but again will freeze while in the home screen. Not sure if it's just a coincidence that holding stop even helps or just repeated attempts to get it going.
    Would this be a firmware or hardware issue?
    It's a great wifi enabled smart BluRay player and I'd like to get it going again. It's just a little over a year old
  • caphair
    • Nov 2011
    • 1249
    Re: Sony BluRay Player - Locks up
    Spoke to a Sony tech and they had me try resetting the player by holding play and power buttons for 10 seconds.
    That got it to turn off and attempt a boot but it still hangs. They wanted $80 for a replacement! Thing was $100 brand new.
    Anyone know if this issue sounds like firmware and it's pretty much "bricked"?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      I'd crack it open and look for bad caps.
      A working TV? How boring!
      • caphair
        • Nov 2011
        • 1249
        I checked and the power board caps looked fine, don't have an esr meter. Main board had two smd aluminum electrolytic caps. Would those bulge if bad?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Those caps would bulge from the bottom if they were bad.
          Have you checked any voltages?
          • RJARRRPCGP
            • Jul 2004
            • 6304
            I would crack it open and reflow the power input section.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • caphair
              • Nov 2011
              • 1249
              I checked voltages from psu to main board and didn't see any fluctuations. Only two voltages 5v and 12v.
              • caphair
                • Nov 2011
                • 1249
                Power input section? Am I looking for a specific chip? I'll try to post pics when I'm home
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  First, I would try the power input connector.
                  Arc A770 16 GB
                  • caphair
                    • Nov 2011
                    • 1249
                    Reflow that? It's only 4 terminals
                    • caphair
                      • Nov 2011
                      • 1249
                      Here are some pics. It appears there's always two 12v present with unit on or off and they're both present and don't waver.
                      I measured voltage at the + side of the two smd aluminum caps one is 5v and the other 12v, they might be for the bluray drive though considering their location.
                      Not sure where to proceed from here.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        I would also reflow the 6 diodes.
                        Arc A770 16 GB
                        • caphair
                          • Nov 2011
                          • 1249
                          On the psu?
                          • caphair
                            • Nov 2011
                            • 1249
                            So a friend has a similar unit without wifi but the power boards are identical, he let me swap them to see if there's any change and still giving the same symptom. That rules out any psu fault.
                            Any ideas what to try on the main board?
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              sounds like a firmware issue to me,have you tried looking for any updates via usb from sony?
                              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                              • bogosort
                                Sony DVD player stuck tray (DVP-SR310P)
                                by bogosort
                                I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                                Anyone knows why?
                                Thank you....
                                05-11-2024, 04:29 PM
                              • Carlos#2003%
                                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                by Carlos#2003%
                                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                02-15-2024, 07:52 PM
                              • mikey5791
                                Sony CFS-5000S radio cassette player no FM reception
                                by mikey5791
                                Hi forum members,
                                In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                                Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                                I opened the casing inside and checked for any dry solder, burned component or loose wires...
                                02-24-2023, 03:48 AM
                                MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                09-06-2024, 05:30 PM
                              • dkneyle
                                Sony KDL-46HX850 Can't upgrade/update firmware
                                by dkneyle
                                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                09-25-2024, 10:44 PM
