Comparing mosfet's
  • Crashr
    • Jun 2014
    • 6
    Comparing mosfet's
    I am working on an abs control module, I had found some articles about replacing one of the mosfet's fixing it. The original part number for it seems to be obsolete now and mouser.com offered a substitute. I have a comparison of the two but am not familiar with the specs for these to know if the replacement would be suitable. Any help will be greatly appreciated.
    http://www.mouser.com/Search/CompareProducts.aspx
    Re: Comparing mosfet's
    The link to MOUSER does not show the MOSFET .
    What is the sub P/N and the original P/N?
    • Crashr
      • Jun 2014
      • 6
      I accidentally put the wrong link on the post here are the links I meant to put up.
      This is the link for the substitute
      http://www.mouser.com/Search/Product...252bMExQ%3d%3d
      This is the link for the obsolete part
      http://www.mouser.com/ProductDetail/...tVSyHe2ddHNnis
        • 31138
        piece of advice,
        dont trust the crap on the screen, Mouser is often full of errors - like saying that is 250w and then saying it's 3.7w
        read the actual datasheets.
          The sub should work.
          BTW, MOUSER showing is correct, the 3.7W/250W (or 3.7W/158W) rating has to do with "SOA curve for voltage derating." as shown in the notes of the datasheet.
          SOA:
          https://cdn.badcaps-static.com/pdfs/...4eb5480feb.pdf
          https://cdn.badcaps-static.com/pdfs/...0b222215ff.pdf
          • Crashr
            • Jun 2014
            • 6
            Thanks for taking a look at it Bud. Looking at all those specs was a little overwhelming, I am trying to learn more about that end of the electronics but it takes a while.
            • redwire
              • 3912
              Look at the MOSFET avalanche rating, the old part (which has a single avalanche rating?)
              This spec is really important for automotive MOSFETs and separates the men from the boys. Most are rated for a single hit (=small die) even though voltage and current specs are the same.
              Pulsing inductive loads (like ABS or fuel injectors) you need to match this or your new MOSFET will die.
              Last edited by redwire; 10-30-2014, 09:47 AM. Reason: read datasheet; need more coffee
              • Crashr
                • Jun 2014
                • 6
                I'm not sure what data to compare and whether the new one should have higher specs or lower specs to to be a good replacement redwire. I looked at the avalanche data and for the new one I see (current/time and current/temperature) but for the old one all I see is (current/temperature).
                • redwire
                  • 3912
                  You did a good job of matching parameters.
                  I look at the package, pinout, VDS max, ID max, on-resistance, logic-level or not; VGS(th), body-diode ratings, SOA curve as some of the main ones.
                  The power MOSFET market is extremely competitive and some important specs are exaggerated or omitted from datasheets.
                  Avalanche rating is important for automotive MOSFET's:
                  The SUM110N05 is repetitive avalanche rated for 180mJ at <1% duty cycle, on a 0.1mH inductive load.
                  The SUP75N06 is single avalanche rated for 280mJ at <1% duty cycle, on a 0.1mH inductive load.
                  So which is the stronger part?
                  Power door locks are a single pulse, but ABS or Fuel injectors, they are continuously pulsing and so the repetitive avalanche rating is more important.
                  • Crashr
                    • Jun 2014
                    • 6
                    Thanks Redwire I really appreciate the help. I will go ahead and order the SUM110N05 then since it sounds like it will be a better part than the original. That original mosfet being a single avalanche is probably why these modules are all going bad then.
                    • Longbow
                      • Jun 2011
                      • 623
                      The OP has found a very good substitute in my opinion. As far as single and repetitive avalanche ratings, this type of rating is likely speculative - much of the information in these data sheets usually is.
                      Don't let the spec sheet stand in the way of progress with your control module. I'd be interested in hearing about your findings. A faulty FET should be easy to spot - I wouldn't bother replacing parts that don't test bad.
                      You might get lucky and find a typical ABS schematic but I've never seen one. We know that they contain motor(s) that are pulsed at a relative low rate, and it is a good assumption that power MOSFETS are used to drive those motors. Do ABS motors need to rotate in both directions? If so, you probably have an H-bridge drive arrangement with at least 4 FET's.
                      We also know that the ABS motors don't get much use, and might freeze up if the car isn't used for some time. So, faulty or frozen motors, faulty drive electronics, who knows? A final thought is that switching of inductive loads has become quite sophisticated. We don't expect the body diode of the transistor to absorb 100% of the inductive spikes any more. H-bridge drive circuitry is controlled by micros that anticipate the reverse voltage and constantly reconfigure the bridge to minimize damage to the drive parts.
                      Let us know.
                      Is it plugged in?
                      • BlackScreen_22
                        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                        by BlackScreen_22
                        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                        I had no problems connecting mosfets and capacitors,...
                        08-27-2024, 12:46 PM
                      • kotel studios
                        Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                        by kotel studios
                        Finally got time to fix this board up.
                        At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                        Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                        04-22-2025, 05:08 AM
                      • flerre
                        Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                        by flerre
                        Hi!
                        Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                        No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                        So, could I safely assume all of these 3 mosfets are...
                        03-13-2022, 12:14 PM
                      • NanoTesting
                        Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                        by NanoTesting
                        I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                        With charger it turns on, fan spins but gives no image.
                        Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                        Reflashed BIOS, same problem.
                        Replaced both main mosfets.
                        Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                        10-30-2024, 10:48 PM
                      • debruina
                        Pioneer VSX-859RDS with all mosfets gone
                        by debruina
                        I am working on a pioneer VSX-859. It started with only one problem but i ended up with a lot more. Probably caused by me
                        Anyway it started with a DSP NG message on the display. That one was easy and was caused by a bad 5v rail. Replaced the capacitors and the message was gone. Everything seems to be working except for a blob sound every time i switched from source. Eventually i tracked that down to a leaking battery on the analog board. Repaired some via's and lines and everything worked ok. That same circuit also caused a not working DCdetect protection. ...
                        08-29-2023, 11:54 AM
