Reusing EPROM's
  • pentium
    • Mar 2006
    • 2778
    Reusing EPROM's
    Recently I tore a whole bunch of Z80 cpu's and 256k windowed EPROM's out of some register terminals and I have a question.
    After you blank the EPROM chips, can you just plug them into a programmer and use them again?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Reusing EPROM's
    Yes, but you'll need a UV eraser to erase them. You can't erase them electrically.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Reusing EPROM's
      yes.
      look for a germicidal lamp.
      its a clear fluorescent tube.find one sized to fit a fixture you alredy have.
      i use a 15w 18" in an aquarium hood.
      careful though as they will destroy your eyes if you look at it without some sort of glasses.
      • pentium
        • Mar 2006
        • 2778
        Re: Reusing EPROM's
        Will the lamp out of a UV pond sterilizer cut it?
        Find Nedry!
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Reusing EPROM's
          yes.
          thats what mine was for.
          i think its a g15t8
          • pentium
            • Mar 2006
            • 2778
            Re: Reusing EPROM's
            Now they are blank, how do you reprogram them?
            Find Nedry!
            • starfury1
              • May 2006
              • 1256
              Re: Reusing EPROM's
              you will need a eprom burner of some type
              One I used to have was for a PC AT....you will then of course need software
              There some stand alone jobs and you may find constructional projects for them on the net.
              you will have to check the details on the eproms you are using as some had different voltages and possibly (if memory serves pinouts slightly different).
              (some pins I think had double functions)
              Really depends on who made it I suppose are they like 27C256 ?
              At the 256K level they may be a bit more standard ...dont know, but the old 16/32K were a bit of a mixed bag.
              So yeah a Eprom burner that supports what you got is what you need, they will probably be a garden variety.
              I would chase up the specs on them to be sure thought
              you got me thinking back 20+ years now....
              HTH
              Cheers
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • starfury1
                • May 2006
                • 1256
                Re: Reusing EPROM's
                BTW don't over cook them
                • pentium
                  • Mar 2006
                  • 2778
                  Re: Reusing EPROM's
                  Yep, they are the 27C256 variety.
                  Find Nedry!
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    Re: Reusing EPROM's
                    I've got an EETools RomMax that is designed for use with PC's up to 166Mhz (Needs an ISA slot). I used to use it for programming BIOS chips back when they were socketed, but it has been sitting around for years now
                    I'll see about posting a pic of it when I get home. I'd let it go pretty cheap if someone can use it. Only problem is you need an old DOS computer cause it won't work in Windows.
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      Re: Reusing EPROM's
                      Here's a rom programmer. This is just a little one, they get much bigger and more expensive. Up to ~$10k or so for a full featured setup that can program anything under the sun.
                      Newer ones are USB, or at least paralell port. This one uses a dedicated control card and can only program up to 8 meg 32 pin chips.
                      • pentium
                        • Mar 2006
                        • 2778
                        Re: Reusing EPROM's
                        That's just like what I want.
                        Quick connect AND isa-based interface.
                        You must of paid a pretty penny.
                        Find Nedry!
                        • starfury1
                          • May 2006
                          • 1256
                          Re: Reusing EPROM's
                          I meant to get back to this post earlier
                          Yeah Maxx thats the type of thing I had....it was dos based.
                          Think pentium probably has an old box that could handle it
                          heres one I found on the net
                          eprom programmer
                          this should give you an insight on how they work but its not a complete page on one Here
                          (seems there selling not giving you a constructional artical)
                          another page here
                          second page here is good for understanding what what with an eprom but I think you maybe past that level pentium site here
                          this is dealing with 64's and when they mention Turbo Pascal 5.5 you know its old but some info may help site here
                          (links seem to be dead)
                          Dont know how accurate, good or works well any of the above is but hope it helps
                          Cheers
                          • Maxxarcade
                            • Jul 2006
                            • 973
                            Re: Reusing EPROM's
                            I tried to sell the RomMax a while back and couldn't get $25 for it It cost about $200 new I think.
                            • starfury1
                              • May 2006
                              • 1256
                              Re: Reusing EPROM's
                              mine was about that too
                              • pentium
                                • Mar 2006
                                • 2778
                                Re: Reusing EPROM's
                                would something like that also be capable of dumping the contents of an eprom/prom chip?
                                I have an SGI here that has buggy eprom chips. I could be able to revive the system if I could reload them with either a chip image or a copy I debugged.
                                Find Nedry!
                                • starfury1
                                  • May 2006
                                  • 1256
                                  Re: Reusing EPROM's
                                  yeah they should read as well as write eproms....
                                  Thats the idea program reprogram.
                                  good luck with it Pentium....I know I had some fun doing stuff like that
                                  • Maxxarcade
                                    • Jul 2006
                                    • 973
                                    Re: Reusing EPROM's
                                    Fixing/updating Eproms is what I used it for. It can save chip contents to a file, and most programmers even have a simple built in hex editor. I would have used the RomMax a lot longer if it had supported chips bigger than 8 meg.
                                    What type of chips are you working with? If they are EPROMS, they usually will start with 27 in the part number. Such as 2716, 2764, 27256, 27010 etc.
                                    Edit- I just remembered you said 27C256. Those will work with almost any programmer. That's another thing I liked about the RomMax, it had the ability to auto-detect most types of EPROMS. Different brands use different voltages and timings for programming.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      Re: Reusing EPROM's
                                      Oh so you can dump the contents of a chip from one of these?
                                      Find Nedry!
                                      • starfury1
                                        • May 2006
                                        • 1256
                                        Re: Reusing EPROM's
                                        yep read it, save as a file and work on it the dump it back.
                                        mind you its usually a saved hex file
                                        So whatever software you use would have to be able to disassemble this.
                                        In the old days you would use, say assembler to write the program then compile it to the hex code file for burning.
                                        I am guessing if you are wanting to edit BIOS chips you are really going to need the the manufacturers software for this.
                                        Unless you know what hex bits at what addresses to change there is not much you can do with the hex editor.
                                        suppose it really depend on what you working on and how you are going to use it.
                                        If you just want to do a straight copy and save the file as a backup
                                        no worries with that
                                        • Nevillet
                                          Reusing an old laptop screen
                                          by Nevillet
                                          I'm looking at reusing an old laptop screen with a controller board.
                                          Below is a picture of the screen and the link is to a controller board on Ebay.
                                          Does anyone have experience of doing this and could share a few words of guidance?
                                          One question: Does the power to the controller board provide illumination power for the screen?
                                          https://www.ebay.co.uk/itm/224299385461
                                          Many thanks...
                                          02-27-2021, 02:45 PM
                                        • DarinC
                                          Reusing power supply from HP LaserJet RM1-5315
                                          by DarinC
                                          I'd like to repurpose this power supply into another project. Could someone give me tips on what to connect to get it to power on. I assumed it would be simple like turning on an ATX (connecting green to ground) but I haven't figured it out yet....
                                          12-16-2021, 03:30 PM
                                        • couillu76
                                          yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
                                          by couillu76
                                          before you start the procedure read the bios eeprom and save it you might need it at the end
                                          1do not power on your svod yet
                                          2plug you ribbon 30x0.5 to the left of the keyboard connector
                                          3test pin with testeur if it beep go to next stage
                                          4 open svod software select 1.8v
                                          5 now plug your svod
                                          6 select nuvoton
                                          7 plug charger on the board/laptop
                                          8 press read id
                                          9 select 256k
                                          10 read nuvoton
                                          11 save reading, now unplug the svod
                                          12 open HxD software and open your 256k file the one you just saved
                                          13look...
                                          03-26-2023, 06:19 AM
                                        • osbln
                                          PS5 Controller BDM-010 CAP values
                                          by osbln
                                          When replacing the sticks, despite carefully taping the components, I probably tore off some capacitors. I suspect that the shrinking Capton tape tore them off.
                                          Can anyone tell me what values the capacitors in the picture have and what form factor they have?
                                          Thank you very much.
                                          08-25-2025, 11:42 AM
                                        • dadopo
                                          sony MCM2250
                                          by dadopo
                                          Hi everyone, I wanted to ask for an opinion, I have 2 identical monitors, only the firmware and serial numbers change, 1 has a faulty card, the other I should put the firmware and serial number of the faulty card in the other working one, in the photo there are 2 eproms, the one on the bottom left of the processor and the one on the top right, I changed them, but nothing has changed, do you think I can do other tests?
                                          Thanks to everyone...
                                          02-02-2025, 09:31 AM
