Reusing EPROM's
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Reusing EPROM's
    I'm in Arizona and once tried erasing some UV EPROMs with sunlight by placing the chips so they faced south and were tilted about 45 degs. Almost all of their bits were erased after just one day, most chips were completely erased in two days, and three days seemed to be enough for 100% erasure.
    I've heard of people programming UV EPROMs in sockets intended for EEPROMs by making a few modifications, including maybe a +12V supply line where the programming voltage normally goes.
    • pentium
      • Mar 2006
      • 2778
      Re: Reusing EPROM's
      I got myself another stack of windowed EPROM chips.
      They range from 256k to 512k and were all pulled from IBM PS/2 systems.
      I also found a good use.
      Someone on the net is offering an Onyx IP25 board with a missing PROM chip. What says hat it's impossible to just make a new one off and image?
      Find Nedry!
      Check the Vending machines!!
      • yildirim05
        • Mar 2015
        • 11
        • turkey
        Re: Reusing EPROM's
        http://s3.dosya.tc/server/9qenu5/Uni...t_2.0.rar.html
        bios copy
        • Nevillet
          Reusing an old laptop screen
          by Nevillet
          I'm looking at reusing an old laptop screen with a controller board.
          Below is a picture of the screen and the link is to a controller board on Ebay.
          Does anyone have experience of doing this and could share a few words of guidance?
          One question: Does the power to the controller board provide illumination power for the screen?
          https://www.ebay.co.uk/itm/224299385461
          Many thanks...
          02-27-2021, 02:45 PM
        • DarinC
          Reusing power supply from HP LaserJet RM1-5315
          by DarinC
          I'd like to repurpose this power supply into another project. Could someone give me tips on what to connect to get it to power on. I assumed it would be simple like turning on an ATX (connecting green to ground) but I haven't figured it out yet....
          12-16-2021, 03:30 PM
        • couillu76
          yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
          by couillu76
          before you start the procedure read the bios eeprom and save it you might need it at the end
          1do not power on your svod yet
          2plug you ribbon 30x0.5 to the left of the keyboard connector
          3test pin with testeur if it beep go to next stage
          4 open svod software select 1.8v
          5 now plug your svod
          6 select nuvoton
          7 plug charger on the board/laptop
          8 press read id
          9 select 256k
          10 read nuvoton
          11 save reading, now unplug the svod
          12 open HxD software and open your 256k file the one you just saved
          13look...
          03-26-2023, 06:19 AM
        • osbln
          PS5 Controller BDM-010 CAP values
          by osbln
          When replacing the sticks, despite carefully taping the components, I probably tore off some capacitors. I suspect that the shrinking Capton tape tore them off.
          Can anyone tell me what values the capacitors in the picture have and what form factor they have?
          Thank you very much.
          08-25-2025, 11:42 AM
        • dadopo
          sony MCM2250
          by dadopo
          Hi everyone, I wanted to ask for an opinion, I have 2 identical monitors, only the firmware and serial numbers change, 1 has a faulty card, the other I should put the firmware and serial number of the faulty card in the other working one, in the photo there are 2 eproms, the one on the bottom left of the processor and the one on the top right, I changed them, but nothing has changed, do you think I can do other tests?
          Thanks to everyone...
          02-02-2025, 09:31 AM
