power ccfl backlight from mains 240v AC?
  • frosty3907
    • Sep 2014
    • 30
    I've got an old 42 inch backlight array with inverters i was going to hack together into a coffee table infinity table.
    Powering with a 24v 9a adapter and 3.8v to on/off only succeeds in illuminating for two seconds before a shut down, i read about this elsewhere on the site and apparently people had success bypassing a controller IC designated oz*something by applying 2v to pin 1 after lifting it from the PCB, i found oz9982gn on mine but couldn't find solid data on pins or required voltage. I measured it in circuit and at power on it goes to ~150v(?!) And then down to 4.8v steady.
    I tried lifting it and applying a steady 5v but the circuit doesn't complete, pretty sure I'm using the wrong pin.
    Anyway; is there a better way than going ac-dc-ac?
    Can you power the ccfl's directly or with a simple (cheap) adapter from 240v AC?
    Otherwise is there a way I can bypass the protection and cram the 24v into the transformers whether they want it or not?
    Thanks guys
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: power ccfl backlight from mains 240v AC?
    or your ccfl/inverter has a defect?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I don't think you can light a CCFL with 240VAC directly mainly because the voltage isn't high enough to strike. Even if you could, you still need the large inductor ballast to make sure it doesn't do thermal runaway.
      Usually when a good fluorescent ballast controller detects that the bulb is missing, it will shutdown to save itself...
      • frosty3907
        • Sep 2014
        • 30
        It has 16 lamps, they all light and appear fine.
        Guess this should be moved to TV repair?
        • xxxvirus1987xxx
          unlegendary
          • Sep 2014
          • 24
          • philippines
          their are only twoo reason for that
          iether bad inverter section.
          or cfl or backlight problem activating the protect sytem to shutdow yung tv unit...
          bypassing the controller for inverter sometime dangerous to other components....
          test all the cfl if it is working fine....use cfl tester improvise etc..
          to confirm if the cfl are realy bad or not....gud luck..
          also try this......
          https://www.badcaps.net/forum/showthread.php?t=10419
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • mikey5791
            Help on Samsung Syncmaster T220 dead ccfl lamp
            by mikey5791
            This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
            Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
            10-18-2020, 03:17 AM
          • chopduel
            Bad mains power causing TV malfunctions?
            by chopduel
            I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
            Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
            • TV would randomly turn off then back on.
            • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
            • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
            12-29-2024, 03:20 AM
          • rblack711
            Vizio D55un-E1 COF Lifting Tabs - Not!
            by rblack711
            Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking...
            08-24-2022, 12:52 PM
            Design of CCFL Backlight Inverters with Frame & Bar Cores
            Summary
            Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
            The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
            The frame and bar ferrite cores, described in this brochure, are especially designed...
            10-07-2024, 04:26 AM
