Need Help Identifying A Diode
  • RetroComputingGrotto
    • Aug 2023
    • 103
    • United Kingdom
    I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
    Click image for larger version  Name:	20250922_124115514_iOS - Copy.jpg Views:	0 Size:	3.13 MB ID:	3730365
    Click image for larger version  Name:	20250922_121407623_iOS.jpg Views:	0 Size:	368.6 KB ID:	3730367
    I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
    We have accounts with RS Components, Farnell, CPC and Mouser so I need to try and find the correct ones from one of these sites, any help (as always) is greatly appreciated as I'm learning all the time!
  • lotas
    • Jan 2016
    • 4718
    • Russia
    SM5100C VOLTAGE 100 V 5.0 A Schottky Barrier Rectifiers
    • truclacicr
      • Apr 2019
      • 340
      • australia
      The top line is a YWW (Year / Week) date code, eg week 01 of 2011 or 2021.
      https://www.google.com/search?imgtyp...Cisz%3Am&udm=2
        • Aug 2023
        • 103
        • United Kingdom
        Thanks!
        Cheers!
          • Aug 2023
          • 103
          • United Kingdom
          I've had a look on RS Components and there are 6 variations that they sell, do I need a specific one or will the cheapest ones do?
          VSSAF5M10HM3/H - https://uk.rs-online.com/web/p/schot...s/2387528?gb=s
          VSSAF510HM3/H - https://uk.rs-online.com/web/p/schot...s/2387514?gb=s
          VSSAF5103-M3/I - https://uk.rs-online.com/web/p/schot...s/2799498?gb=s
          VSSAF5M103-M3/I - https://uk.rs-online.com/web/p/schot...s/2799503?gb=s
          VSSAF5103HM3/I - https://uk.rs-online.com/web/p/schot...s/2799496?gb=s
          VSSAF5M103HM3/I - https://uk.rs-online.com/web/p/schot...s/2799501?gb=s
          Thanks again, all help much appreciated as it's saving things being thrown away after just a few years of use.
            • 31170
            check the datasheets - those are different size/shape packages.
              • Aug 2023
              • 103
              • United Kingdom
              I think I've worked it out, the letters at the end appear to be how they are packaged either individually or on a roll I think so as I'm only ordering a few and not thousands to put in a machine that really doesn't matter. The only other thing I can see different on the datasheets is the operating temperature is either 150 or 170 (or something like that) so doing a bit of digging around (and asking AI Co-Pilot) I believe the operating temperature of the ones I have is 150 so I have ordered some of those ones so we shall see how we go!
              • CapLeaker
                Leaking Member
                • 8303
                Don’t worry about their op temp. You gotta be more concerned about the speed, voltage and rectification current.
                if you want you could put a 200 or 400v 10A diode in there as long as the rectification speed is at least same as fast as the original diode and if it fits. Diodes are more forgiving.
                Why do you think these 2 diodes are bad? Did you take them out of circuit and measure them?
                  • Aug 2023
                  • 103
                  • United Kingdom
                  Yes. One measures correctly and one measures short circuit. I believe they are in parallel together which is why in-circuit they both measure short-circuit.
                  Click image for larger version  Name:	20250922_141953198_iOS.jpg Views:	0 Size:	257.7 KB ID:	3731976
                  • CapLeaker
                    Leaking Member
                    • 8303
                    Anything that is in pairs, like diodes, MOSFETs etc replace both.
                      • Aug 2023
                      • 103
                      • United Kingdom
                      I've got 25 on the way and I have de-soldered them both ready to be replaced by two shiny new ones!
