help identifying a component
  • jamesg1979
    • Jul 2025
    • 14
    • United Kingdom
    Hi there, i purchased a faulty pure dab radio from ebay and after some testing i found that this ic i believe is possibly a mosfet? has failed and caused a short on the board. I have typed the numbers in google but cant find any info at all. I am very new to electronics but i am learning. would anybody have any idea what it is and if there is an equivalent component i could try. With the chip off the board i get 5.4v on pin 1, pin 3 is ground as is pin 6, and on pin 8 i have 4.5v. i know this is quite vauge but im hoping someone could help. Thanks
    • 31166
    which radio is it?
    btw, stay away from dab radio's - they are all built like shit.
    (probably to relfect the bitrate!)
    • jamesg1979
      • Jul 2025
      • 14
      • United Kingdom
      Hi, it is a pure evoke H3. Sold as no power. When i initialy gave it voltage i had a current draw of 1.9a and about 8 components were getting hot .I removed the ic simply because it was the first component to show heat on the thermal camera. Since removing all the shorts are gone so i presume it has failed internaly.
      • jamesg1979
        • Jul 2025
        • 14
        • United Kingdom
        After a little bit of reserch (using gemini ai) it looks as though it could be a switching regulator. Chances of finding an equivalent component without knowing the output voltages is probably not going to happen. I guess i need to keep my eye out for another faulty unit with hopefully a different issue.
          • 21477
          It`s made by Monolithic power but don`t know what it is yet - https://www.badcaps.net/forum/troubl...20#post1482820
          Is that first character an eight or a capital b B
          • jamesg1979
            • Jul 2025
            • 14
            • United Kingdom
            It is a 8
            • truclacicr
              • Apr 2019
              • 335
              • australia
              Show us a photo of the PCB. If the IC is a switching regulator, there should be an inductor nearby.
              • jamesg1979
                • Jul 2025
                • 14
                • United Kingdom
                Here is the best picture i can take with my phone at the minute. You can see the empty pads where i took the chip from. i believe there is an inductor just before the ic marked l204
                • jamesg1979
                  • Jul 2025
                  • 14
                  • United Kingdom
                  Just to add, I have now purchased another radio off ebay with a different fault so hopefully I will be able to test the component and at least figure out my voltages. You never know, there may be a ic I could get to make this one work too. Fingers crossed. Worst case scenario I get one fully working radio and I didnt pay much money. But its the fault finding is what makes it worth it for me.
                    • 21477
                    It is a 8
                    Looks like it could be MP20045DQ
                    https://www.monolithicpower.com/en/mp20045.html
                    Datasheet https://www.monolithicpower.com/en/d...ument_id/1201/
                    Marking 8K**
                    Package info
                    https://www.monolithicpower.com/en/s...formation.html
                    https://media.monolithicpower.com/cm...%20MARKING.pdf
                    • jamesg1979
                      • Jul 2025
                      • 14
                      • United Kingdom
                      That chip has only 6 pins and is 3mm×3mm. My chip has 8 pins and is 4mmx4mm. 🤷‍♂️ Unless im looking at the wrong one. I did check all the 4mmx4mm chips in there list but they all look like bga chips too me. But again I might be (and probably am) wrong. 😁
                      • truclacicr
                        • Apr 2019
                        • 335
                        • australia
                        MP20045DQ has 8 pins, plus the pinout matches the circuit. And it's a linear regulator, not switchmode.
                        • jamesg1979
                          • Jul 2025
                          • 14
                          • United Kingdom
                          You are right I do apologise, I just downloaded the data sheet and it indeed has 8 pins. All I saw was the initial image on the screen which showed 6 pins.
                          this is looking very promising. I really appreciate your guys help you are all very knowledgeable and I can learn a lot from all of you.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5022
                            • New Zealand
                            Heat does not always mean a short
                            Voltage regulators can get hot due to overloading caused by shorts elsewhere
                            The question is are the other hot parts up, or downstream, electrically, from the regulator?
                            -David VanHorn
                            • jamesg1979
                              • Jul 2025
                              • 14
                              • United Kingdom
                              The parts were upstream, consisting of various components, including a diode, resistors and caps.
                              • jamesg1979
                                • Jul 2025
                                • 14
                                • United Kingdom
                                Sorry the diode was downstream from the chip not upstream. All other components come after. I removed the diode and it tested good
                                • shelby5041
                                  clock radio / radio lifespan?
                                  by shelby5041
                                  hi
                                  ive got a modern digital clock radio approx 15yrs old
                                  my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                  since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                  the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                  it uses very little power just a few watts i would imagine that may have something...
                                  09-14-2024, 03:30 AM
                                • UserXP
                                  Vintage SONY Digital Clock Radio ICF-C12W no audio
                                  by UserXP
                                  Dear all,
                                  I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                  i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                  My question is, do you know of this brand of capacitors and how bad are...
                                  07-21-2025, 08:35 AM
                                • tyler123456
                                  Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                                  by tyler123456
                                  Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                                  I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                                  I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                                  Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                                  Anyone...
                                  08-16-2024, 12:51 PM
                                • praveenramavath
                                  Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                  by praveenramavath
                                  Hello All,
                                  I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                  https://www.hifivision.com/threads/m...-screen.98243/
                                  Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                  04-26-2025, 09:08 AM
                                  HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                  09-12-2024, 02:00 PM
