17pw26-4 replacement
  • cossiejay
    • Nov 2010
    • 83
    hi can anyone tell me if a replacement has to be out of the same tv ,I have just bought a replacement fitted it and the fault is the same it wont come out of stand by thank you
  • vinceroger69
    • Mar 2012
    • 6714
    Re: 17pw26-4 replacement
    as far as i know as long as the psu is a exact match 17pw26-4 there shouldnt be a issue do they look identical on the top of the board and also on the bottom side? have you tested both the old board and new board voltage on all the connectors are they identical?.what tv are you working on make and model it may be a main board fault im sure tom66 will chime in regarding these 1726pw-4 im sure he worked on a few
    • cossiejay
      • Nov 2010
      • 83
      yes they are spot on the same the tv is a Sanyo CE32LD47-B the old power board the stand by light stayed on the replacement board the stand by light flashs all the voltages are ok until the main board is plugged in the the invertor drops to 18v the 12 volt drops to 8 the 5 volt drops to 3 I hear a faint clicking on the power board and the optical light flashs at the same rate as the clicking
      • vinceroger69
        • Mar 2012
        • 6714
        sounds like mainboard or invertor board is loading it down can you unplug the invertor board from the main what happens then?
        • cossiejay
          • Nov 2010
          • 83
          yes tried the invertor and it is the same I have also unplug everything but the main board and front switchs and it does the same
          • vinceroger69
            • Mar 2012
            • 6714
            sounds like a mainboard fault im sure other members will be along to help trouble shoot
            • cossiejay
              • Nov 2010
              • 83
              thank you the seller of the replacement has offered a refund so that's something
              • cossiejay
                • Nov 2010
                • 83
                it is the main board will I need a new one or is there a eeprom I can change cheers
                • boosti45
                  Macbook pro logic board replacement parts quesion
                  by boosti45
                  i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                  08-21-2024, 05:23 AM
                • tuner2000i
                  Philips 65PUS8518/12 distorted image after main board replacement
                  by tuner2000i
                  hello everyone,
                  I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                  The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                  07-15-2025, 01:15 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Cvrado
                  Led TV Board Replacement, same part number and model, different size
                  by Cvrado
                  Hello my friends!
                  I have a question that I think you can answer and help me with!
                  I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                  So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                  My concern is that the board won't draw enough voltage to the bac...
                  03-02-2024, 05:05 PM
