Solid vs wet lifespans
  • volumetricsteve
    • Jul 2014
    • 32
    I've been working on recapping an older motherboard which already had some seriously high-end caps onboard. I was thinking I would try to make the switch from electrolytic to solid-state to add longer life to the board, prevent leaks, ect. When I snoop around on digikey, it seems like the high-end electrolytic caps have rated life spans of something to the tune of 5000 hours at 105C while solid-state caps with the same uf and voltage ratings come in around 2000 hours at 105C.
    I did see one "wet tantalum" that appears to be indestructible but it's also $133 per unit. too rich for my blood.
    Shouldn't the solids be spanking the pants off electrolytics in terms of life span?
    Thanks!
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: Solid vs wet lifespans
    In my older macs, Ive switched to tantalum on the motherboards and have had no problems, they had surface mount electrolytes that loved to leak, the tantalums are supposed to last alot longer but time will tell.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • volumetricsteve
      • Jul 2014
      • 32
      that's what I'd expect...maybe I'm reading my results wrong or I'm looking in the wrong places..
      other than digikey, where would you go for caps?
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • eccerr0r
        solid polymer electrolytic capacitor go boom?
        by eccerr0r
        Anyone had a solid polymer capacitor fail for whatever reason?
        How do they fail? Do they explode, go open, short out, ?
        How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
        Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
        07-25-2022, 07:12 AM
      • Perry Babin
        Electrolytic cap endurance
        by Perry Babin
        From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
        Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
        Why do polymer capacitors...
        10-18-2025, 05:21 PM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • ajdrenter
        Picking caps for Antec SU-380
        by ajdrenter
        In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
        https://www.badcaps.net/forum/showthread.php?t=14159
        It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
        05-13-2023, 10:40 AM
