Any one here good at 360 hacks ( nand ) ?
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    Hello everyone .
    I guess this board is not familiar with xbox 360 stuff but i have really got no support from specialized forums since they require buying some products to give support .
    So am running a small business nowadays , and am recovering some consoles to sell them after .
    I have a console that comes without dvd reader , so i must get the dvd key to install another drive in it .
    But to get that key i must install a hack in the console witch is the rgh hack .
    This hack requires having a good extraction of the console's nand witch contains all the consoles programs and details ( menu ) .
    But one extraction ( dump) is not enough , because we need multiple dumps to compare them and get a match , that's when we make sure the dump is good to go .
    But in my case i have done 6 dumps , and there is no match between them .
    So is there a possibility to build one clean dump from all the dumps ??
    NB: the dumped file is in hex and the size is 16.5 mb , the extention is bin
    • 31125
    Re: Any one here good at 360 hacks ( nand ) ?
    no, you ned to fix your jtag.
    if you have fitted a gltcher board then for get the dvd drive - it will be able to store the games on a harddrive.
    look here for info without buying stuff.
    http://www.eurasia.nu/index.php
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Not sure if someone is still reading this, but... What method of reading the nand are you using? If it's the lpt method try getting a matrix nand reader. They are a lot cheaper than the nand-x and can get the job done. If you are using some sort of a nand reader resolder everything with flux. Also what kind of wires are you using? Don't use tick wires! Use low resistance ones. If it still doesn't work with a nand reader try the lpt method.
      Also I know it doesn't seem logical, but unplug the xbox HDD before doing the read.
      If you need any more info/assistance post here I'll keep watching the thread.
      P.S. Shorter wires might also help.
      Keyboard not detected, press F1 to continue...
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • irepair559
        Ps4 1215a hdmi diode readings good everything good but no pic??
        by irepair559
        PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
        01-05-2023, 12:32 AM
      • sohail5307
        Need a2159 128gb nand bin file
        by sohail5307
        I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
        Two nand are using :
        Tsb4226(128gb)
        Tsb4226(128gb)
        09-16-2023, 09:20 PM
      • tech_guru
        Macbook Pro 2019 A2141 NAND Shorted
        by tech_guru
        Hello. If you could please help me understand what I am doing wrong...
        This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
        I also replaced the tps power ic for the ssd.
        Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
        08-28-2025, 08:04 AM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
