http://www.electronickits.com/kit/co...meas/ck105.htm
I have a decent meter at work but i'd like one for home. I thought it would be interesting to build it myself.
Besides, i wan't to know if it works out before i waste my money destroying an ESR meter kit.
If you are using or planning to use a digital multi-meter in your training programs, you must consider this training kit. It is easy to assemble and comes with a complete training course, using sequential assembly procedures and testing. Specifications: 3.5 inch digit display, 34 ranges, 20 amp AC-DC current, measures capacitance and transistors.
Features:
• Extra Large 1" Display 3.5 Digits
• Transistor & Diode Test
• Overload protection
• Capacitance to 200uF
• Audible Continuity Test
• AC/DC Current Measurement to 20Amps
• Low Battery Indication
• Rubber Holster w/ Tilt Stand
• Safety input sockets for test leads.
• Includes 9 Volt Battery, Test Leads, and Manual
Specifications:
• Size: 3.5"W x 7. 5"L x 1.4"D
• AC and DC Volts: 200mV, 2V, 20V, 200V, 1000V, 750VAC
• Accuracy: 0.5% DC, 1% AC
• Resolution: 0.1mV
• AC and DC Current: 200µA (DC Only), 2mA, 200mA, 20A
• Accuracy: 1% DC, 1.5% AC, 20A 2%
• Resolution: 0 .1µA
• Resistance: 200 ohm, 2K ohm, 20K ohm, 200K ohm, 2M ohm
• Accuracy: 0.8%, 3% 20Mohm
• Resolution: 0 .1 ohms
• Capacitance: 2nF, 20nF, 200nF, 2uF, 20uF, 200uF
• Resolution: 1pF
Specifications:
• Resolution: 0.1mV
• Resolution: 1pF
Ordered the DVOM kit.
- It works when you read the color code correctly.
