Is anyone familiar with Elenco M2666K
  • gastorgrab
    • May 2007
    • 320
    http://www.electronickits.com/kit/co...meas/ck105.htm
    If you are using or planning to use a digital multi-meter in your training programs, you must consider this training kit. It is easy to assemble and comes with a complete training course, using sequential assembly procedures and testing. Specifications: 3.5 inch digit display, 34 ranges, 20 amp AC-DC current, measures capacitance and transistors.
    Features:
    • Extra Large 1" Display 3.5 Digits
    • Transistor & Diode Test
    • Overload protection
    • Capacitance to 200uF
    • Audible Continuity Test
    • AC/DC Current Measurement to 20Amps
    • Low Battery Indication
    • Rubber Holster w/ Tilt Stand
    • Safety input sockets for test leads.
    • Includes 9 Volt Battery, Test Leads, and Manual
    Specifications:
    • Size: 3.5"W x 7. 5"L x 1.4"D
    • AC and DC Volts: 200mV, 2V, 20V, 200V, 1000V, 750VAC
    • Accuracy: 0.5% DC, 1% AC
    • Resolution: 0.1mV
    • AC and DC Current: 200µA (DC Only), 2mA, 200mA, 20A
    • Accuracy: 1% DC, 1.5% AC, 20A 2%
    • Resolution: 0 .1µA
    • Resistance: 200 ohm, 2K ohm, 20K ohm, 200K ohm, 2M ohm
    • Accuracy: 0.8%, 3% 20Mohm
    • Resolution: 0 .1 ohms
    • Capacitance: 2nF, 20nF, 200nF, 2uF, 20uF, 200uF
    • Resolution: 1pF
    I have a decent meter at work but i'd like one for home. I thought it would be interesting to build it myself.
    Besides, i wan't to know if it works out before i waste my money destroying an ESR meter kit.
  • gastorgrab
    • May 2007
    • 320
    Re: Is anyone familiar with Elenco M2666K
    There's also a cheapy Cap meter for $29.95.
    CM9601A - 3.5 DIGIT CAPACITANCE METER
    http://www.electronickits.com/gold/capacitancemeter.htm
    The CM9601a Digital Capacitance Meter uses a Dual-Slope Integration A/D Converter Measurement System. Our price of $29.95 is not a misprint, meters of equal quality sell for over $100.
    Features:
    • High Accuracy.
    • 2-3 Second Measurement Rate Update.
    • Low Battery Indicator.
    • Zero Trim Pot.
    • Alligator Clip Test Leads.
    • Over-range Indication.
    • starfury1
      • May 2006
      • 1256
      Nope I am not
      The one or two build your owns in OZ are the $10 cheapies (think it was 30 odd for the analog) so that looks like a better kit....
      (although the build your owns cost more go figure)
      not that I look at a lot of specs seems they are always some what close to each other
      (except if your are talking Flukes maybe)
      They seem a tad better then average....but thats working from memory.....
      If that is the IC I think it is ICL7106, that chip has been around for a very long time
      So guess any circuits build around it have been tried and trued if you get what I mean.
      I think from memory it was the basis for a lot of project electronics mag type meters too.
      Here's the pdf on the ICL7106
      Building your own I think is a good way to get an idea of "how" the meter does things
      An analog is probably best in this regard but mostly now its digital meters.
      So guess digital with it more complex way of doing things is what your going to get these days.
      Having an old analog is handy I think as there are just some things that are easier to do with them.
      (pitty is now there are very few if any decent quality ones made although I haven't looked for a long time)
      The increase of VLSI and integrated circuits has made it possible to build relatively high quality gear at a cheaper price.
      So that cap meter does look like good value.
      (being in mind thought it a capacitance meter not an ESR meter)
      Here for the above items with similar spec you be paying $80 odd AU.
      going off topic here but something I thing needs to be considered
      for electronics and meters
      Generally speaking
      Digital is good but it does suffer from the problem of no visual start and end point of reference.
      This is way even thought the cockpit of an FA18 maybe full digital the interface to the pilot is an analogue.
      Same with car speedo's and for that matter clocks
      In valve days techs would know if the voltage was right just by the velocity of the needle on the meter
      Unfortunately these days a few hundred millivolts could mean the difference between a circuit working correctly or not
      If it was me for that money Id grab them both for general stuff
      , but thats $US not $AU
      (maybe better stuff for near same money US wise)
      although nothing like rolling your own, you built it and it works......
      Just my thoughts on it
      Cheers
      • gastorgrab
        • May 2007
        • 320
        If that is the IC I think it is ICL7106, that chip has been around for a very long time So guess any circuits build around it have been tried and trued if you get what I mean.
        Thats what it looks like in the instruction manual;
        Ordered the DVOM kit.
        The capacitor meter can wait until i know what to do with it.
        • starfury1
          • May 2006
          • 1256
          Basically the capacitance meter will give you the capacitance and thats all
          The multimeter has capacitance range but not up to the range of the capacitance meter (more useful for the large electro's on MB etc)
          My meter is very similar but no pop up screen
          Jaycar Q1572
          (note the Au price)
          It is a pity they don't do them with ESR as this has become a measurement to know these days. (and possibly more help in trouble shooting)
          Take your time and double check your work with construction
          Good luck and hope its a raving success for you
          cheers
          • gastorgrab
            • May 2007
            • 320
            Thank You much!
            Finally, somethig i can use the 35w iron on.
            Although it's great for taking them out, the 60w iron was making me nervous while putting caps in. I guess i've been quick enough with it though. So far every MB i've touched is working. (5 total)
            • gastorgrab
              • May 2007
              • 320
              The solder provided with this kit is garbage.
              I know it's the solder because i tried the stuff i use for caps and the joint came out shiny and smooth under the microscope. The solder they gave me looks like frost under the microscope. It's the right shape but i don't tust it.
              I hope i don't cook the first 4 components with the desoldering braid, especially the electrolytic. It's only 22uf and doesn't look too sturdy.
              The 35 watt iron is a touch hot for this task but i'll manage.
              • gastorgrab
                • May 2007
                • 320
                Hmmm. Could the solder be reacting to the Kester Tip Tinner?
                According to the manual the provided solder is 63/37.
                • gastorgrab
                  • May 2007
                  • 320
                  What the hell? All i wanted to to was check out replacements for things i might have to replace.
                  The color code is different from the spec. Is this an error?
                  http://www.dannyg.com/examples/res2/resistor.htm
                  • gastorgrab
                    • May 2007
                    • 320
                    - It works when you read the color code correctly.
                    • gastorgrab
                      • May 2007
                      • 320
                      I've completed steps A (the display section) and B (the DC voltage section) and everything seems to pass the tests given. It was only when i set the incomplete board in the case did i realize that i mounted the fuse holder on the wrong side of the board.
                      Oops. This board isn't as sturdy as a motherboard. When i desoldered the fuse holder one of the pins that i bent to hold the part in slightly lifted the foil a bit as i pulled the part out. I resoldered it and although it's around .5 mm high on one side it still has plenty of meat to conduct properly. The actual trace is on the other side.
                      I retested and it still works. When i finish the project i'll support it with a drop of cyanoacrylate. I use this stuff at work called Tak-Pak and it works very well for this sort of thing.
                      Tomorrow i'll post a couple of pics of my progress in case anyone is interested in trying this kit themselves.
                      • gastorgrab
                        • May 2007
                        • 320
                        It's not as complicated as it looks. The instructions are fairly clear.......but there is still room for confusion.
                        A few pics;
                        The foil that lifted can almost be made out in these pics. I don't anticipate any trouble with my repair.
                        • gastorgrab
                          • May 2007
                          • 320
                          Awwwwww, dammit!
                          I forgot all about this.......and i've only a little futher to go. I should just finish it up tomorow.
                          ......after a couple of beers.
                          • chth96
                            by chth96
                            03-09-2024, 10:03 PM
                            12-31-2023, 06:04 AM
                          • jorpec
                            by jorpec
                            Hi
                            Thnaks
                            01-23-2023, 10:37 AM
                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                            12-14-2023, 07:45 PM
                          • Stephan Mathers
                            EDMI ATLAS MK10 Electronic Meter Discussion
                            by Stephan Mathers
                            Greetings, new guy here but always interested in the crazy universe of modding
                            We just finished construction of around 25 vacation houses, all inside the same private area.
                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                            05-20-2025, 09:09 AM
