Bump proof switch?
+ More Options
Posts
  • mathog
    • Mar 2010
    • 2655
    Bump proof switch?
    I need to install a switch in the trunk of my car. The electrical specs are nothing special - DPDT 3 or 5 A at 12VDC. The problem is that it needs to be "bump proof" - it has to stay the way it set no matter what moves around in the trunk and hits it. Ditto for any car motions, not just normal vibrations, but even a smallish collision. (A big one and it won't matter.) It is going to be "panel" mounted in the plastic trunk linker, so it should not stick out too far.
    So far I have not found a solution that I like. There are toggle switches with flip up covers, like this:
    http://www.autobarn.net/plsw26.html?...FQIvaQodBo8A-g
    but I don't much like the look and they are really designed for cockpits, and control panels, not trunks.
    Perfect would be something where there is a locking screw, for instance, that had to be loosened before the switch could move. (Tools are OK because the switch only changes position when the car is being serviced in a certain way.)
    I thought about using a regular rocker switch, and then custom making a cover that screws down over it. That will work, but somebody, somewhere must sell something like this already.
    Any ideas?
    • 31015
    Re: Bump proof switch?
    rotary switch is the answer.
    there used to be special toggle switches that you had to lift/pull to move but those are very rare outside of the military suppliers.
    • R_J
      • 9535
      Here are a couple dpdt switch with cover or you can just get the cover, or there are ones that you need a key to operate
        • 31015
        the toggle switch is no good,
        the cover only fits down in one direction intentionally.
        hard to turn on, fast to turn off!
        • R_J
          • 9535
          Missed that he did'nt want that type of toggle. There are those slide switches used on some power supplies for changing input voltage, you need screwdriver to slide them, they look something like this
            • 31015
            i'v never seen a dpst / dpdt one, only single pole.
            not seen them in catalogs either - only psu's
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              hidden fuel pump switch?
              • R_J
                • 9535
                I found these, maybe they would work for you?
                http://cpc.farnell.com/1/3/dpdt-selector-switch
                http://www.newark.com/arcolectric-sw...ac/dp/06WX0743
                • mathog
                  • Mar 2010
                  • 2655
                  These I think (see page 9 of the PDF)
                  http://www.mouser.com/ProductDetail/...FYk7MgodGTIAcQ
                  The sliding voltage range switches are looking pretty good.
                  Thanks.
                  • R_J
                    • 9535
                    This and some duct tape
                    • Elysarian
                      • Mar 2013
                      • 200
                      • United Kingdom
                      How about one of these?
                      http://cpc.farnell.com/1/1/28750-key...-2-lorlin.html
                      keep the key next to your ignition key and you won't be without it.
                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 05:30 AM
                      • Natob82
                        Micro Momentary Push Switch?
                        by Natob82
                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                        12-21-2022, 05:22 AM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
                      • SluggerB
                        Help making a switch work the opposite way with a relay
                        by SluggerB
                        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                        02-07-2025, 07:57 PM
                        Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                        by sam_sam_sam
                        Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                        ( needs more cam circuits for the machine to work correctly again )
                        https://www.ebay.com/itm/275321870186
                        To
                        3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                        ( not 4 positions but the right amount of cams circuits )
                        https://www.ebay.com/itm/274660439950
                        I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                        03-18-2023, 05:12 PM
