What is this component?
  • DiamondTech61
    • Aug 2021
    • 63
    • united kingdom
    Can someone tell me what this is? Ive seen it a LMC7101 but apparently theres an A and a B version, will either work? Its for a car GPS thats powered from a 3.7v battery if thats any help, thanks in advance!
  • truclacicr
    • Apr 2019
    • 352
    • australia
    SE9016
    http://seawardinc.com.cn/Site/defaul...6-20230525.pdf
    • lotas
      • Jan 2016
      • 4809
      • Russia
      Same with EC49016
      And SD8016
      • DiamondTech61
        • Aug 2021
        • 63
        • united kingdom
        OK thank you guys for your help!
        • EvazX
          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
          by EvazX
          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
          However, after some time, the replacement motherboard...
          08-25-2025, 06:09 PM
        • Hannibal_Hector
          Samsung UN39EH5003FXZA won't stay powered off
          by Hannibal_Hector
          Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
          03-02-2021, 07:57 PM
        • spleenharvester
          Apparently red = negative now?..
          by spleenharvester
          I cut in half a two-core DC5525 male-female extension cable to splice in an LC filter. My computer didn't come back to life after plugging it in, and then a few seconds later... BOOM!
          Naturally my first thought was that I'd fitted the capacitors the wrong way round. Nope, the cable uses red as negative and white as positive. I didn't think to check that the barrel matched the colours as I've literally never encountered this before in my life, but you learn something new every day apparently!
          RIP two new Panasonic FMs 😞 Fortunately my system and power supply are OK...
          10-03-2025, 12:44 PM
        • abajor
          A1990 820-01814A U1200 very hot when powered up, USB drawing > 4A
          by abajor
          I have this machine. It powers up and gets fan spin, will even shut down when I hold the power button.
          U1200 gets very hot under thermal camera, the next hottest region is UB000 and L7030. I'm assuming L7030 is warm due to charging.
          Do I have a potential dead CPU? or just a dead U1200? Not sure what to check since everything is powered up.
          04-11-2025, 05:02 AM
        • MobileXT
          Yamaha DXR15 Powered Speaker Fault LED On
          by MobileXT
          Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here...
          01-17-2025, 12:43 AM
