What to do with spent li-ion battery cell how to responsibly get rid of them
    • Jul 2011
    • 6070
    I have a lot of spent battery and need to find a new home for them
    Anyone have any ideas for a responsible solution for this issue
    • 31260
    deplete them with a load
    trashcan
      • Jul 2011
      • 6070
      trashcan
      Are you sure about this
        • 31260
        works for me.
        the way i see it, governments dump their shit in the ocean or burn it.
        so why should i give a fuck?
          • 31260
          i'll add,
          it's a stainless-steel or nickel case with a roll of paper in it.
          the paper it coated in a sludge containing a tiny amount of lithium - that is mined out of the ground in the first place,
          and the rest is mostly cobolt - also mined from out of the ground.
          so not really an enviromental threat imo.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            My local government provides a battery recycling service at the landfill, though unsure what they do with it. They explicitly do not want the batteries in the landfill, maybe just because of the fire risk. Also lead batteries are removed from the landfill lane of course, those can be easily recycled despite lead also being mined from the ground...
            Ultimately at this point lithium ion cells have too much "other" crap in it making it hard to recycle unlike lead batteries. This is compounded by the fact that is similar to the plastic recycling problem - there is too many different kinds and nobody cares enough about iron phosphate, manganese dioxide, or cobalt dioxide differences just the same as nobody cares about polyethylene, polypropylene, or polyvinyl chloride.
            • petehall347
              • Jan 2015
              • 4445
              not many places set up to deal with them . l looked into setting up a place to recycle them . there are lots of hoops to jump through plus it costs lots of money . looks maybe lucrative if done correctly . the chemistry changes inside them and create new things that are wanted . cant remember what right now .
                • 31260
                not much lead in "lead" batteries these days.
                they just lead-plate some crap metal like zinc to save money.
                if they still made them like in the old days they would be pretty valuable to scrappers
                  • 31260
                  small batteries look fun!
                  https://www.youtube.com/watch?v=tBg4ximDrsk
                    • Jul 2011
                    • 6070
                    This was on 60 Minutes last night about how to deal li-ion battery packs that become damaged and dangerous to be around watch the hole clip very interesting concept for dealing with this type of issue
                    https://www.instagram.com/60minutes/reel/DH3_0Y8xF2E/
                    It is a instagram video clip unfortunately it is only part of the story
                    Here is the full video segment of the story that I found very interesting
                    https://www.youtube.com/watch?v=iYFksPCL-I8
                    Unfortunately you do have to have a YouTube account to be able to watch it this is the one you to watch the hole video clip especially towards the end of video
                      • Jul 2011
                      • 6070
                      The website is giving some issues posting the website link
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        Lead acid batteries are still all lead else it would be much more difficult to recycle/scrap them, and at least here in the USA scrappers readily take car batteries, dead or alive. The zinc would react with the sulfuric acid too causing acid loss.
                        And yes lithium ion cells with any lithium metal in them are potential fire hazard, as bad as nickel metal hydride with any hydrogen stored...
                        • tmhobadcap
                          Lithium ion cell voltage not going up after 3.8V
                          by tmhobadcap
                          I got a chromebook with battery problem. It was charging when plugged in. But the indicator just showed that the battery was below 10% no matter how long it was plugged in. I took the battery pack out. There are two cells in series. Each cell had a voltage of about 3.7V. I charged one of them with a lithium cell charger. I can see current going into the cell at about 500mA. After several hours, the voltage was just about 3.8V. I charged it again manually by connecting 4.2V to it from a power supply and set the maximum current to 500mA. I can see about 100mA going into the cell. But the voltage...
                          02-03-2025, 01:30 PM
                        • i440bx
                          Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
                          by i440bx
                          Hey there,
                          I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
                          The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
                          It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
                          As written above, I plugged in a new CMOS cell and checked...
                          08-19-2024, 02:28 PM
                        • eccerr0r
                          Sell or Shim Solar panels?
                          by eccerr0r
                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                          So now what to do with these small panels?
                          I could sell them...
                          Or I could shim them....
                          03-29-2025, 01:07 AM
                          Nokia 5510 Cell Phone Schematic
                          Nokia 5510 Cell Phone Schematic...
                          10-31-2024, 02:12 PM
                          Nokia 2600 Cell Phone Schematic
                          Nokia 2600 Cell Phone Schematic...
                          10-31-2024, 02:10 PM
