Please help me to identify this IC (THAC KHD) and Mini PC Mainboard
  • Hauke
    • Jan 2017
    • 78
    Hi!
    I got a defective mini PC mainboard which I am trying to repair.
    I don't know the model of the mini PC and I can't find anything about this board online.
ID:	3597030 Click image for larger version
    When plugged in with USB-C the board does nothing. But it drains about 1.7W.
    I noticed, that one component near one of the two USB-C ports get's quite hot (>80°C).
    Since I don't have the schematics, I don't really know what component this is. I assume it is some kind of USB-C power or protection controller.
    It is labeled "THAC KHD", has 9 Pins and is BGA soldered. I desoldered it, to take some pictures.
    After desoldering the board power consumption went down to 0W.
    .Click image for larger version
ID:	3597032Click image for larger version
    Does anybody know what this component actually is? How likely is it to break?
    Thank you very much!
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    On pcb under bga9 ic, have you short on some pins, shorted output? Check area arround hdmi, it look like component on data lines have hole in it... maybe some lightening strike product...
    • Hauke
      • Jan 2017
      • 78
      Good find!
      I guess your assumption is right and the board was destroyed by a lighting or something similar.
      I desoldered the bad parts at the LAN and graphic interfaces and supplied power through usb-c. The power consumption increased to ~15W and after about a second, one die on the CPU exploded.
      So this board is now for parts only..
      Anyway, thank you for your help!
      • FriedFred
        • May 2024
        • 140
        Too late for now, but use always a good power supply, where you can adjust the current, not only the voltage. And start with 100mA or so. Then you can find shorted parts without sacrifice the CPU.
        • adam7
          • Jan 2017
          • 16
          • Kazakhstan
          Hi Hauke,
          It is FPF2495UCX.​
          • truclacicr
            • Apr 2019
            • 352
            • australia
            https://www.mouser.com/datasheet/2/3...95-1300797.pdf
            • Hauke
              • Jan 2017
              • 78
              Hi adam7 and truclacicr
              Thank you for your answers!
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • thesame
                DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                by thesame
                Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                02-27-2024, 04:31 AM
              • k-krzych
                Identify board to board connector
                by k-krzych
                Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                07-08-2025, 12:32 PM
