Multimeter Settings
    master hoarder
    • May 2008
    • 12175
    Re: Multimeter Settings
    Originally posted by stj
    it would be faster to just hook the pump directly to a good power source and see if the pressure rises.
    +1
    If you have access to the pump's wires, just give it 12V from a spare battery or charger and check pressure again. Beware that some cars have an electronic regulator module (ECM) that gets 12V from the relay/fuse box and then steps it down to a lower voltage based on the engine's fuel consumption needs. My car is like that (2002 Focus). When you turn the key to the ON position (but not start the car yet), the ECM will run the pump for a second or two on 12V and then cut out until the engine is started. Once started and idle, it will feed the pump a low voltage to keep it running at some minimum pressure.
    Originally posted by highspeed
    I have never had a pump slowly die, usually just stops working all at once, that's why I was skeptical about changing it right away. But I have read that these late 90's early 2000's GM cars have this sort of thing happen.
    I guess anything is possible. When my car started giving me problems with the fuel pump, I went to this old guy of a mechanic who has probably had more experience with older cars. He told me he's only seen fuel pumps go out slowly - usually dropping pressure over time and causing the car to loose power. It puzzled him quite a bit when I told him that my car would run great most of the time, but occasionally it would not start due to the fuel pump refusing to run. So he suggested to not change the fuel pump, as he wasn't sure this was the issue and he didn't want me to spend money on a repair he can't guarantee. So he said wait a little longer to see what happens and I listened.
    But turned out it was the fuel pump. And as luck would have it, I got stranded on a rest area in the middle of the night (stopped to take a bathroom break and turned off the car, then I couldn't turn it back on again). I spend an hour trying to get the fuel pump running by cycling the ignition key between ON (not start) and OFF positions - a trick that used to work a dozen of times prior to the pump failing completely.
    • RetroComputingGrotto
      New Toy UNI-T UTi260B - What Settings?
      by RetroComputingGrotto
      I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
      After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
      I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
      09-02-2025, 08:36 AM
    • wnlewis
      New wire for my RDE3340 Whirlpool electric range
      by wnlewis
      OK. I got the rocker switch figured out thanks to the good advice on this forum.
      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
      This is a Whirlpool RDE3340 electric range.
      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
      Where may I find parts...
      01-08-2025, 11:21 PM
    • i440bx
      Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
      by i440bx
      Hey there,
      I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
      The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
      It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
      As written above, I plugged in a new CMOS cell and checked...
      08-19-2024, 02:28 PM
      ZD-915 vacuum pump motor mount service alert
      If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
      One note this unit has been repaired already once because of switching power supply regulator ic chip failure
      Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
      The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
      09-19-2021, 02:15 AM
    • emeskay
      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
      by emeskay
      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
      08-06-2024, 07:13 AM
