Anybody knows anything about this TO-220 MOSFET? I found some references to it being IRF3205, probably for OEM deliveries since I've taken it out from some APC UPSes…but nothing for sure.
International Rectifier 94-2354 transistor
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None -
Re: International Rectifier 94-2354 transistor
This one? 110A rating is about right since it running at 12~48V batteries but at high current to drive the inverter transformer.
https://cdn.badcaps-static.com/pdfs/...f46737462a.pdfNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I don't know from what part of the UPS it is so I won't even guess. Just desoldered bag of power transistors and diodes and now I am trying to find what they are. I got few IRF3205 as well and than these 94-2354. Found references of them being EOL (not lead-free) so they are genuine and existing part. But no datasheet whatsoever.Less jewellery, more gold into electrotech industry!
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
by Steph.henHi all, a newby question about a bridge rectifier I'm trying to identify.
I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?... -
by unimatrix93Hello everyone,
I'm trying to fix up my battery charger. Where I found a dead schottky rectifier.
This is the dead component PTR30L120CTF:
PTR30L120CTF datasheet(1/7 Pages) PFC | 30A 120V HPTR Schottky Rectifier (alldatasheet.com)
And I have a spare 30CPQ150:
30CPQ150 datasheet(1/5 Pages) IRF | SCHOTTKY RECTIFIER (alldatasheet.com)
Can I use this diode as a replacement or if not, can you recommend me a proper replacement?
I cannot find the exact unit anywhere besides aliexpress and such.
Thank you guys!
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by elsomerhi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...1 Photo
by rddubeHello everyone,
I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...-
- Loading...
