oooo nice!
    • 31283
    oooo nice!
    what kind of damage could we do with a few of these?
    http://www.alibaba.com/product-detai...48041.html?s=p
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: oooo nice!
    Fast charge flash light
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • mariushm
      • May 2011
      • 3799
      Re: oooo nice!
      You can use several of them as car battery replacement. Spot welding maybe...
        • 31283
        Re: oooo nice!
        i was actually thinking about maybe using them as the primary source in a coil-gun.
        but the price needs to come down a lot first.
        5 of those would give me a 5KA load-dump!!!!!!!!
        you could also use one to prime a directional emp cannon.
        (not that i would of course )
        • desert-rat
          • Mar 2014
          • 4103
          Re: oooo nice!
          Its only rated at 2.7 volts . Still if you put a bunch togher you could use them as a battery and run a car off them .
            • 31283
            Re: oooo nice!
            amps over volts anyday when your after a bang!
            volts give you a bright flash and maybe a burst of x-rays, but amps give you molten metal!
              Re: oooo nice!
              "Nanocarbon graphene" LOL.
              If they lie about that, I wonder if the capacitance rating is actually correct?
              You can get some good ultracapacitors from surplus sites like Elec Goldmine.
              • desert-rat
                • Mar 2014
                • 4103
                Re: oooo nice!
                I just wounder if this is for real , a 5000 f cap in what looks like a D battery .
                  • 31283
                  Re: oooo nice!
                  if you look at the foto's,
                  that "D cell" looks more like a 500ml beer can or larger!
                  • desert-rat
                    • Mar 2014
                    • 4103
                    Re: oooo nice!
                    Even in a budwiser size can its hard to believe putting a 5000 f cap in that space . This is more the kind of cap I am usted to seeing .
                    http://www.johnstonesupply.com/store...ep?pID=G36-079
                      • 31283
                      Re: oooo nice!
                      oh it's doable all right,
                      but it's not gonna discharge in a burst - atleast not without some damage.
                      datasheet says the charge time for 5000Farad is 10seconds to 10min's (maybe over the temp range)
                      and the ESR is .23
                      so they have the capacity, but speed wise they are more like a battery.
                        master hoarder
                        • May 2008
                        • 12175
                        Re: oooo nice!
                        IIRC, graphene was discovered not that long ago. I think it was about a year ago when someone showed me a video that mentioned the possibility of huge supercapacitors based on graphene. So maybe they are finally here. Pretty cool tech, IMO.
                        Electric go-carts, anyone?
                        Enough of these in series/parallel should give you the same results as lead-acid batteries. The added advantage is that you can deep-cycle discharge them without issue.
                          • 31283
                          Re: oooo nice!
                          you could re-charge your electric car in 10 seconds.
                          the only 2 problems are:
                          1: it would probably cost over 10,000$ for the "battery" pack.
                          2: you would need to hook it up to the local grid to get the current.
                          having said that, the packs from honda and toyota are so expensive that it may be feasable.
                          you need 200v minimum.
                          so about 70 caps - i wonder how much space that would take up.
                            master hoarder
                            • May 2008
                            • 12175
                            Re: oooo nice!
                            If each cap is about the size of a 330 mL soda can... a standard pack has 12... so 6 packs (72 cans). That's maybe a bit bigger than the size of a gas tank? (or not? - I'm not that much of a car person)
                            Even if the "battery pack" is as expensive as you said, I still think it would be worthwhile as long as that minimum 1 million number of charge cycles holds true. I doubt any regular battery can come close to this figure.
                            • av4x
                              Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
                              by av4x
                              Good morning, everyone!
                              I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
                              First up is a Fujitsu Lifebook U7511.
                              It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
                              Model: Fujitsu Lifebook U7511
                              CPU: Intel Core i5-1135G7
                              GPU: Intel Iris Xe Graphics
                              RAM: 16GB DDR4 - 3,200 MHz
                              PCB manufacturer: ASKPCB?
                              PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
                              Damage: Liquid damage
                              The liquid probably...
                              11-01-2025, 03:09 AM
                            • rounin
                              MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                              by rounin
                              Device Information
                              • Model: MacBook Pro 14” M1 Pro (A2442)
                              • Logic board number: 820-02443-05
                              Original Issue
                              The device suffered liquid damage, causing a short circuit on the logic board.
                              Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                              Work Performed
                              Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                              Current Status
                              • When powered on, the screen shows support.apple.com/mac/restore....
                              10-20-2025, 11:15 PM
                            • adrianekspert
                              Looking for schematic – RS Welding Systems WIG-STEUERUNG (906383 / 906384, RS1)
                              by adrianekspert
                              I’m currently working on a project focused on diagnosing and reconstructing the control electronics of RS1 / RS Welding Systems Leipzig (WIG-STEUERUNG) welders.
                              I’m looking for the schematic diagram or any technical documentation of the main control board labeled 906383 / 906384, used in RS1 TIG/MMA welding machines.
                              The board includes:
                              • two UBICOM TDS38070 microcontrollers,
                              • EEPROM 24C256,
                              • analog ICs such as LM358, TL062, MC33153, MAX4515,
                              • a gas valve control section (BD135 / IRF8G30 / optocouplers P621),
                              • connectors labeled Display, Netzteil,
                              10-19-2025, 06:14 AM
                            • Joel Ohana
                              Lenovo IdeaPad 3 15IAU7 that suffered water damage
                              by Joel Ohana
                              I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                              Symptoms:
                              • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                              • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                              What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                              03-06-2025, 11:25 AM
                            • azozexd
                              Need help hp 725 g3 liquid damage
                              by azozexd
                              Hello freind i have hp elitebook 725 g3 White liquide damage
                              after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
                              could some one tell me the value of this resistor
                              Thank you...
                              12-15-2024, 06:01 PM
