Looking for schematic – RS Welding Systems WIG-STEUERUNG (906383 / 906384, RS1)
  • adrianekspert
    • Jan 2022
    • 9
    • Polend
    I’m currently working on a project focused on diagnosing and reconstructing the control electronics of RS1 / RS Welding Systems Leipzig (WIG-STEUERUNG) welders.
    I’m looking for the schematic diagram or any technical documentation of the main control board labeled 906383 / 906384, used in RS1 TIG/MMA welding machines.
    The board includes:
    • two UBICOM TDS38070 microcontrollers,
    • EEPROM 24C256,
    • analog ICs such as LM358, TL062, MC33153, MAX4515,
    • a gas valve control section (BD135 / IRF8G30 / optocouplers P621),
    • connectors labeled Display, Netzteil, WK, LB, KS, Fernregler, Brenner,
    • and voltage regulators LM2575T-5 / 7815 / 7915, plus several relays.
    I’m particularly interested in:
    • the connection topology between the microcontroller, analog circuits, and EEPROM,
    • the power distribution network (+24 V, ±15 V, +5 V),
    • and the control path for relays and gas valve.
    In exchange, I can share:
    • high-resolution photos of both sides of the board,
    • EEPROM dumps and working firmware versions,
    • and a growing RS1 technical database (diagnostics, firmware, tuning, power supply).
    Any help, partial schematic, or technical hint would be greatly appreciated.
    Many thanks in advance for your support!
  • SidneyCanadas
    93C46 and 93C56 EEPROM
    by SidneyCanadas
    I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
    https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
    Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
    06-14-2023, 01:16 PM
  • dmccul2698
    Pioneer DEX-P99rs "No EEProm " diagnostic code.
    by dmccul2698
    Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
    1). Understand the schematic and check the connections between the EEProm and DSP
    2). Check the functionality of the EEProm
    I don't know if this is the unit's problem but it's a place to start.
    I have little to no electronic experience...
    04-08-2024, 05:32 PM
  • edgarmg15
    Damaged EEPROM on TV Vizio E320-A0
    by edgarmg15
    Hi everyone
    I´m trying to repair a TV Vizio E320-A0 that I found in the street
    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
    11-19-2022, 03:46 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • harp
    triac phase control 0-100%
    by harp
    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
    06-02-2024, 09:00 AM
