Motor start capacitor.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Current Cap 7.5uF +/-5% actual 2.5uF
    Replacement I found I 6.6% greater 8uF
    Only thing I am thinking of is temperature increase in start winding.
    In theory I would expect it to provide more start toque and slightly higher running temp is this correct.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Motor start capacitor.
    a .5uf increase will not have a significant increase in temp. it may on torque but it depending on the motor.
    Follow the white rabbit.
      Once the motor starts spinning, the start up cap is no longer connected to the circuit, it is only used for starting not for running. You are talking start up not running cap, right?
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        yes run capacitor the machine will run if you help it start otherwise the motor just rotates slowly.
        My pc
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didnยดt start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
