Vanquish CMH lighting system Controller Board
  • Gadjet
    • Aug 2012
    • 248
    Ok so let me run you through the chain of events, the controller stop coming on no video, after checking the board they were lots of shorts on the board. I removed the screen a couple disappeared, then I removed the cpu and more disappeared, lastly I removed the memory chip and all shorts were gone. (The 2 chips circled in red are the memory and cpu) Also there is an issue with the 5v test point that is circled it’s reading 12v and so is a 3.3v regulator next the power jack.
    Ordered a new CPU and Memory chip and installed them, reconnected the screen and all shorts are gone. Reconnected the power to check the 5v point and 3.3 regulator and the chip you see in the picture started smoking. Now my issue is what is that chip “CA7 TL” ( the Amazon screen shot is the regulator that’s next to it that was read 12v)
    All help is Appreciated, Thanks
  • truclacicr
    • Apr 2019
    • 309
    • australia
    https://www.mouser.com/datasheet/2/3...08-3223887.pdf
    • harp
      • Jun 2022
      • 598
      • Planet Earth
      Now my issue is what is that chip “CA7 TL”.................. SY7208
      • Gadjet
        • Aug 2012
        • 248
        Thanks, harp sucks Mouser has them markered as obsolete I just got the CPU and Memory from there. @truclacicr Thanks for a place where I can purchase it another 2 wks is going to suck as well. Got another question either of you have an idea of why it went up in smoke I was able to plug it up no problem before replacing the 2 chips. Was it the 3.3 regulator?
        • lotas
          • Jan 2016
          • 4589
          • Russia
          If you replace everything, then it won’t turn on exactly, since the STM32f429... controller has firmware and without programming the required firmware, nothing will start.
          • harp
            • Jun 2022
            • 598
            • Planet Earth
            after checking the board they were lots of shorts on the board. I removed the screen a couple disappeared, then I removed the cpu and more disappeared, lastly I removed the memory chip and all shorts were gone........... can you describe how that your "shorts lots of" look like? How you determine its location? I feel that you desoldered maybe good ic that had parallel connection with short. After dicsonnected screen, have you checked on connector of screen, and on board connector have discover reading short on power rail? The same on desoldered ICs. Low ohms reading not always represent short, or short can be still elsewhere on board............. Also there is an issue with the 5v test point that is circled it's reading 12v ........... if the 5v rail has 12v on it, when you power up device in that conditiion you fry everithing on that rail and maybe on other lower rails feeded by "5v". You must be sure that all voltages are ok before replacing anything, and after you replacing and before powering up, make sure that all power rails have expected resistance (and changed to better regard to past reading), because in the proces may create short (solder bridge, nocked, dislocated component or caps shorted from heatgun)............ I am sorry for the mess, from recently I cant quote properly... https://www.badcaps.net/forum/genera...28#post3474728
            • Gadjet
              • Aug 2012
              • 248
              lotas ok that's not good, I'll double-check the old CPU with the new memory and update the post.
                • 31015
                what resistance do you consider a "short"?
                and did you check both polarities?
                • CapLeaker
                  Leaking Member
                  • 8146
                  You have full power of the input of the voltage regulator on its output pin?
                    Tankless hot water heater controller board not powering up when power is applied
                    by sam_sam_sam
                    I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                    I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                    However I would like to know if I could figure what happened to this controller board if possible
                    Tomorrow I will take some better pictures of both side of both boards
                    The...
                    12-09-2022, 09:14 PM
                  • Grouickman
                    EPILOG Laser - XS002 controller board
                    by Grouickman
                    Hello gus,
                    Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
                    For instance I don't even have the connectors pinout
                    thx.
                    06-10-2025, 11:46 AM
                  • WiredRacing
                    Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
                    by WiredRacing
                    Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
                    I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
                    The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
                    The LCD...
                    08-31-2021, 09:42 AM
                  • dropfry
                    Need help with a wine fridge controller board.
                    by dropfry
                    Model: Frigidaire FFWC18L2QB
                    Board: FX101B PCB16006F1 110 HANYI
                    This fridge was turning on, but wouldn't cool and the fans wouldn't spin in the back. Removed the back panel and found two controller boards and a power supply. The controller board at the top had burn marks under two heatsinked transistors (photo titled Top_Left). They said 13005D on them. I could not find those in America, so after a lot of googling and cross checking datasheets it looks like E13005 are replacments. Tested them with the diode setting and they both look good.
                    Put the board back...
                    10-07-2023, 04:55 PM
