EPILOG Laser - XS002 controller board
  • Grouickman
    • Jun 2024
    • 32
    • France
    Hello gus,
    Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
    For instance I don't even have the connectors pinout
    thx.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    Tankless hot water heater controller board not powering up when power is applied
    I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
    I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
    However I would like to know if I could figure what happened to this controller board if possible
    Tomorrow I will take some better pictures of both side of both boards
    The...
    12-09-2022, 09:14 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • WiredRacing
    Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
    by WiredRacing
    Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
    I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
    The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
    The LCD...
    08-31-2021, 09:42 AM
  • dropfry
    Need help with a wine fridge controller board.
    by dropfry
    Model: Frigidaire FFWC18L2QB
    Board: FX101B PCB16006F1 110 HANYI
    This fridge was turning on, but wouldn't cool and the fans wouldn't spin in the back. Removed the back panel and found two controller boards and a power supply. The controller board at the top had burn marks under two heatsinked transistors (photo titled Top_Left). They said 13005D on them. I could not find those in America, so after a lot of googling and cross checking datasheets it looks like E13005 are replacments. Tested them with the diode setting and they both look good.
    Put the board back...
    10-07-2023, 04:55 PM
