Resistor - what value is this?
  • Hamie
    • Apr 2014
    • 1383
    Posted earlier and didn't get a reply.
    Really need this to complete a repair.
    Need to replace this pink resistor.
    But unsure of value.
    Any advice would be really appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Resistor - what value is this?
    Both the pink ones are the same.
    Looks
    Brown, Black, gold, Red, Black.
    • T30M31
      • Feb 2014
      • 58
      The only match I can find with gold for the 3rd band is for a 4 band resistor. Brown, Black, Gold, Red would be 1 ohm 2% tolerance. The resistors don't appear to be damaged. Have you measured them with an ohmmeter?
        It looks like the Source resistor of the MOSFET next to it.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Looks like a 1.0 Ohm 2% tolerance as stated above. I would think that both might not have burnt out so pull one end of each and do aresistance check.
          • Hamie
            • Apr 2014
            • 1383
            Thanks for the advice guys, its not actually either of the 2 resistors in the picture, i accidently snapped the resistor when working on another part, but its the same as the ones in the picture.
            i also got the same rating 1ohm 2% on the calculator, but the final black band confused me, im struggling to find said resistor anywhere to buy.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I guess as a temporary shot you could use a 5% or 10% 1 Ohm 2Watt resistor if you have any available.
              • lti
                • May 2011
                • 2545
                Measure the resistance of one of the good resistors to make sure they're really 1 ohm.
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • jimjoe123
                  LCD TV Green/Pink screen problem
                  by jimjoe123
                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                  Then each time...
                  02-23-2020, 01:29 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                  Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  09-07-2024, 03:10 AM
