Resistor - what value is this?
  • Hamie
    • Apr 2014
    • 1383
    Posted earlier and didn't get a reply.
    Really need this to complete a repair.
    Need to replace this pink resistor.
    But unsure of value.
    Any advice would be really appreciated.
  • Hamie
    • Apr 2014
    • 1383
    Re: Resistor - what value is this?
    Both the pink ones are the same.
    Looks
    Brown, Black, gold, Red, Black.
    • T30M31
      • Feb 2014
      • 58
      The only match I can find with gold for the 3rd band is for a 4 band resistor. Brown, Black, Gold, Red would be 1 ohm 2% tolerance. The resistors don't appear to be damaged. Have you measured them with an ohmmeter?
        It looks like the Source resistor of the MOSFET next to it.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Looks like a 1.0 Ohm 2% tolerance as stated above. I would think that both might not have burnt out so pull one end of each and do aresistance check.
          • Hamie
            • Apr 2014
            • 1383
            Thanks for the advice guys, its not actually either of the 2 resistors in the picture, i accidently snapped the resistor when working on another part, but its the same as the ones in the picture.
            i also got the same rating 1ohm 2% on the calculator, but the final black band confused me, im struggling to find said resistor anywhere to buy.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I guess as a temporary shot you could use a 5% or 10% 1 Ohm 2Watt resistor if you have any available.
              • lti
                • May 2011
                • 2555
                Measure the resistance of one of the good resistors to make sure they're really 1 ohm.
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                  Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold Acer 14'' boardview and SF114-34-P2H0 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  09-07-2024, 03:10 AM
                  Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  Acer Swift SF114-34-P2H0 + Pack Gold Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift SF114-34-P2H0 + Pack Gold Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2H0 + Pack Gold boardview and SF114-34-P2H0 + Pack Gold schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  09-07-2024, 02:20 AM
