Strange color code on resistor, Help!
+ More Options
Posts
  • double
    • Apr 2014
    • 8
    Hello all,
    I am looking to replace a torched resistor, I am repairing a Power supply and replaced the affected transistors already but still have not figured this resistor out. The color code seams to be BROWN, BLACK, SILVER, GOLD, SILVER,.. which does not make sense, even if the 5th was a "reliability" band.. It measures about 6mm so I believe its ¼ Watt. Its marking on the PCB is R301; definitely not a inductor. Any help would be greatly appreciated.
    Re: Strange color code on resistor, Help!
    Is the 3rd really silver or Grey?
    https://cdn.badcaps-static.com/pdfs/...2bf2eda94b.pdf
    • double
      • Apr 2014
      • 8
      Originally posted by budm
      Take a look at the high res photos. you be the judge..
      The grays im used to tend to have a more flat matte look, in my experience. the brown and black have that matte look as well. the Gold/Silvers usually have more of a foil look. this is the first resistor to really puzzle me.
      is it possible colors were altered when it burned out?
      If the third was gray, the fifth would have to be too (they look identical) and that makes no sense as well because that would make the tolerance gray.
      Whatever color it is, the third and fifth are the same, unless the color got altered, i don't think a manufacturer would make the gray and silver so close in appearance.
        • 30963
        i'v seen these before.
        i think - maybe, that the last band indicates the wattage.
        because it's a fuseable safety resistor.
        • redwire
          • 3900
          It looks like a 0.1R 5% 1/4W metal film flameproof (pink body) resistor (BRN,BLK,SILVER,GOLD) and the 5th band can denote what kind of resistor it is. A white band usually means fusible (for Panasonic and Yageo). But yours is silver? I guess it's another brand. resistor calculator
          Probably current-sense on the source/emitter of the SMPS power transistor.
          • double
            • Apr 2014
            • 8
            I was going to say, Iv heard of white bands denoting fusible, but not silver, but that makes the most sense. I just dont want to replace it with the wrong value..
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I'll start with a 10 Ohm. Then try a 1 Ohm, then the 0.1 Ohm resistors. Hardly think it would be 10 x 8-0s = 1 exp 9-0s may be stretching a bit. :-)
                Can you show us the board and where the resistor is connected to?
                • redwire
                  • 3900
                  double, yeah a picture of the board helps.
                  That (sense) resistor going open-circuit would damage the IC too, from what I have seen.
                  • double
                    • Apr 2014
                    • 8
                    Sorry for the delay, here is a photo. hard to see because heat-sink is in place, you could see "R304" is where the resistor was pulled form.
                    I was looking for a 10.8 ohm resistor with a .05% Tolerance. No dice at mouser or digikey..Actually digikey has a 10.8, .5% 1/2 Watt, which maybe my safest available bet to start..
                    Let me know what you think.
                    • bammbammfran
                      • Apr 2014
                      • 476
                      your last band is silver so it should be 10%
                      digikey does have a 10.8 5% but NOT IN STOCK
                      you're best bet is probably an 11 ohm 5% which they have in several wattages
                      yours is probably 1w based on size, I would go for 2
                      • double
                        • Apr 2014
                        • 8
                        If the last band is silver than so is the third, they are undoubtedly the same colors. It measures about 6mm so I believe its ¼ Wattr..I contacted digikey technical support and they are baffled as well..Id buy another power supply if they weren't so much compared to the cost of the resistor : /
                        • bammbammfran
                          • Apr 2014
                          • 476
                          well since the 4th is gold, I do not think that the 3rd band is that critical
                          the 1watts are 6.5 mm in the 11ohm
                          they do have the 10.5 in 1/4watt MFR-25FBF52-10R5
                          and 10.7 in 1/4watt MFR-25FBF52-10R7
                          for .2 ohms difference, ASSUMING yours is a 10.8, I would use the 11 and a higher wattage
                          they are cheap enough at about 10cents ea, get a couple of each ??
                          • bammbammfran
                            • Apr 2014
                            • 476
                            well
                            I did a bunch of searching and reading datasheets and I found 4 resistors that had a 5th band that was not for tolerance
                            but non were silver
                            I found a white (flameproof), black (flameproof noninductive) and violet (high power) on Yageos
                            and a blue (flameproof) on a TT electronics
                            A few companies do not even mention color codes on their datasheets which didn't help
                            I guess go with your note
                            "I'll start with a 10 Ohm. Then try a 1 Ohm, then the 0.1 Ohm resistors"
                              Can you tell me if one end of the resistor is connected to the + leg of the main filter cap? If it is, then it is fusible resistor for feeding the B+ to the circuit. And because it is blown open, then you may have shorted circuit some where so the components such as diodes, MOSFETs should be checked before installing the new resistor.
                              • bammbammfran
                                • Apr 2014
                                • 476
                                looks like we can add green to a fifth unknown band
                                I have several of these pink bodied ones with X-X-silver Gold-green
                                and I found an even more odd one
                                green bodied- red-red-silver-black-GOLD from an apple G4 supply
                                My tester isn't good under .5 and all these read under .4
                                So I guess that yours might just be a .1 - 5% with an unknown silver band
                                  BTW, this power supply board, what is it used in? Any P/N? I can see it is made by DELTA.
                                    • 30963
                                    green final band = 0.5%
                                    maybe when we see stuff like this, we should meter them to get a bit of info built-up.
                                    i'll keep an eye out from now on and make checks on strange parts.
                                    • bammbammfran
                                      • Apr 2014
                                      • 476
                                      that would be true with the green if the silver and gold were not 3rd and 4th
                                      and I did meter them to below .4ohms which I did mention
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        The last one might be the temp coefficient. Some manufacturers mark that on there as an extra band.
                                        Muh-soggy-knee
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • Askic
                                          Reading resistor value by color band
                                          by Askic
                                          attached is a picture with two resistors. I wonder what values are based on color of the band.
                                          I have used this as a reference:
                                          https://www.electronics-tutorials.ws...tor/res_2.html
                                          Since there are 5 bands, the question is from where to start counting (what is the first band).
                                          Based on this info, I can conclude that thick band is the last one.
                                          Therefore the values are:
                                          Left resistor - red(2) yellow(4) black(0) black (x1) brown (1% tol) = 240 ohm, 1% tolerance
                                          Right resistor - brown(1) black(0) black(0) gold(x0.1)...
                                          02-10-2022, 12:26 AM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
