Hi, good day, could you help me identify this IC? I know it is a 3-valve regulator, however I cannot find any information about this IC on the Internet, nor in the Sylergy or Richtek guides. ic RW=AD
					identify ic RW=AD
			by bajdikCould anyone identify Richtek backlight driver from Samsung LTN173KT01?
There is only "CZ=EL 12M" mark on it. Thank you very much! -
			by deep000My computer monitor ASUS VP249H stopped working, and smoke came out of it.
I opened it and found that a voltage regulator had burned out.
The problem is that I can't identify its reference.
I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality ๐ ).
How can I find its reference, and do you think it's repairable?
Monitor: Asus VP249H
Board reference: 0171 - 2271 - 6083
			by electroelefHi,
I am trying to identify and buy a voltage regulator.
The casing is somewhere between SOT563 and SOT963.
So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
Codes on the capsules are:
AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
pin2 is ground
pin3 is Vin +5v
pin6 is Vout +3v3
pin4 is connected through an L to pin6
I spent quite a while looking for a replacement to buy.
Any help... -
			by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470ยตf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
			by MOSFIT84Hi bro
how to identify this kind of regulator?
PART NUMBER?
Product code : 3H=4M
... - Loading...
