Richtek LED Backlight Identify IC chip 'CZ=EL 12M' - LCD monitor Samsung LTN173KT01 from Asus K70
  • bajdik
    • Aug 2015
    • 68
    • Czech Republic
    Could anyone identify Richtek backlight driver from Samsung LTN173KT01?
    There is only "CZ=EL 12M" mark on it. Thank you very much!
    • 21932
    https://www.badcaps.net/forum/troubl...91#post1225791
    CZ= – RT8561AGQW
    • bajdik
      • Aug 2015
      • 68
      • Czech Republic
      Thank you very much. I looked for CZ=EL and not CZ= only, so I did not find the old post. Sorry and thank you again!
      • DynaxSC
        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
        by DynaxSC
        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
        The behaviour is also really very strange, i.e.:
        • The disk shows always up in BIOS - so it is recognized, so far so good
        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
        02-23-2025, 01:33 PM
        09-07-2024, 05:50 AM
        by momaka
        03-15-2023, 10:17 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
      • myth77
        ASUS PG27U MONITOR
        by myth77
        First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
        03-19-2024, 08:58 AM
