Light bulb limiter
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Light bulb limiter
    Hey friends,
    I would like to build a light bulb limiter circuit to test my amplifier to prevent the newly fitted components burning if there's still a fault in the amp section. The amp is 300watts rated. So can i use 100watts bulb as how everyone uses or i need bulbs watts higher than 300 for example 400 watts bulbs cause my place there's only 100watts bulbs. If i need higher than 300watts, how do i align them? Parallel or series?
    4 bulbs (400watts) in parallel/series?
    Inputs will be highly appreciated.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Light bulb limiter
    the bulbs will be parallel to each other.
    Also it may power on with 100 watts depends on the design.
    Id suggest starting with a 100watt and seeing what happens.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Thanks a lot for the swift reply The power amp is a InterM PAM-360. So 100watts should be enough? I have attached the documents for your reference.
      • SteveNielsen
        Retired Tech
        • 2327
        The worst thing I can imagine is it will trip the current protection relay. Try one and see. If it does trip the relay than add another 100w bulb in series. I think putting it in parallel will halve the load impedance, increase the current and trip the relay again.
          100W is what I use for working on the amp also, the main key is that to find out if the unit has shorted circuit or not, the lamp should come up bright then dim down as the main caps charged up, I do not use the lamp for full audio output test, just for finding out if the outputs or the power supply are shorted out or not. I have bypass switch so I can bypass the lamps, I use two lamp sockets for one of my version.
          http://s807.photobucket.com/user/bud...tml?sort=3&o=0
          http://s807.photobucket.com/user/bud...tml?sort=3&o=1
          • DjKrish
            • Oct 2012
            • 354
            • SG
            I tried 100watts bulb, its kinda dim when turned on. Only the transformer, power board and main board hooked, amp board is disconnected. Does this mean the transformer and power board is working fine? Or the bulb is not enough wattage?
              That is good, it is bad when lamp stays on at full brightness.
              • DjKrish
                • Oct 2012
                • 354
                • SG
                Ok with the amp board plugged in, the bulb is still dim, but the protection light is still on All the components on the amp pcb thats faulty has been replaced, its good as new now.
                  That means the protection circuit still detects large DC offset at the output stages, so you still have more torubleshooting to do.
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    That means the protection circuit still detects large DC offset at the output stages, so you still have more troubleshooting to do.
                    Ive noticed there's 2 variable resistors on the amp circuit. Is there any adjustments need to be made? Or shall just leave it like that as how it is originally? As per the dc offset, ive checked the speaker output terminal with multimeter, it shows zero reading. Please check pictures.
                      So the speaker relay RL301 still not turned on?
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        Yes still not turning on with the red protection light on. Is there anywhere else i should be checking? Please bare with me as im not a pro in repairing but i know how to do stuffs like checking components with meter, checking voltages, soldering and checking schematic diagram and replacing components. Not really a pro in in-depth repairing, that's why i turned here for help. Almost all the main parts in the amp pcb has been replaced. Still no go, luckily im still running the unit with the bulb limiter to prevent those components from burning again.
                          The diagram is really poor, it does not show what is driving the PROT LED (connector AN14 pin 7), on the LED display board.
                          • DjKrish
                            • Oct 2012
                            • 354
                            • SG
                            Yes i know Thats the only diagram i can find on the net. I called interm, they said same model there's a few version of schematics and service manuals. Really kinda stuck now. Really need help on this. I just dont know where else to check anymore. Any possibility on the transformer causing this? Or the power filter caps on the power board? I took out those 2 big caps and tested using ESR, its low esr and uf almost closer to rated value.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Check the voltage on the two main caps (the 2 big ones) and report what it is. Should be equal on both. Also check those white wire-wound resistors and see if any has or have gone open circuit. Better yet, check their resistance and compare to their printed values. Do this with the power off and amp unplugged, of course. Let us know what you find.
                              And to confirm what others said about the 100W light bulb - yes, it should work (as you saw). I myself have tested a Behringer EPQ-1200 that way. As long as the volume is kept down so that the speaker output is under 1W, it should work. Above that (and depending on the amp design itself), it may trip the protection due to low voltage. One trick I like to do is to measure the voltage across the mains voltage after the light bulb. If it falls below 90V, the device you are testing may fail to work normally due to too low of an input voltage. Again, it all depends on the device's design.
                              • lookimback
                                • Aug 2013
                                • 1489
                                I'm trying this and the lamp isn't lighting. I soldered the wires from the lamp to a blown fuse to make it easier. So I have a 100 watt bulb in series, replacing the fuse. I'm getting stby, and the voltage across the pfc cap is 150v off, 160v on. Do I need a lower wattage bulb?
                                ------------signature starts here------------
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  I think I figured it out. I tried a 75w bulb and it lit, real dim, very briefly. I see also that it only lights if the PFC isn't charged.
                                  • ezenia
                                    LUMIMAN Smart Bulb IC ID?
                                    by ezenia
                                    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                    04-28-2025, 05:56 PM
                                  • nicktasios
                                    Macintosh Quadra 840AV PSU
                                    by nicktasios
                                    I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                    12-22-2024, 05:07 AM
                                    Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                    by sam_sam_sam
                                    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                    I also have back when Light of America had these light bulbs available for yard lights
                                    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                    While the Lithonia lighting fixture has all most certain bulb failure
                                    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                    I have only had this light fixture for not more than a year if it...
                                    07-02-2023, 03:45 PM
                                  • Fritter
                                    Bulbs to avoid in current limiter
                                    by Fritter
                                    Just putting my first current limiter together (uk). Apart from led's, are there any bulbs that will not function as needed? Any advice much appreciated.
                                    10-31-2023, 11:24 AM
                                    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 03:40 AM
