Using a non contact voltage detector
  • darkweezil
    • Dec 2013
    • 10
    Could I use a non contact voltage detector to check for faulty components on a tv power board?
    If so,which one would you guys recommend?
  • T30M31
    • Feb 2014
    • 58
    Re: Using a non contact voltage detector
    Highly unlikely!
    • darkweezil
      • Dec 2013
      • 10
      A guy from shopjimmy told me this.
      If you have a voltage detector you can try holding it near the high voltage lines that go from the power supply to the inverter and see if you get anything on them. Please don't try and use a meter to measure this as its high frequency and can damage your meter.
      So I am a little confused.
      Thanks for taking time to help me.
      • T30M31
        • Feb 2014
        • 58
        It all depends on what you are trying to accomplish.
        The non-contact voltage detector may tell you if you have high voltage present but it won't tell you what level of voltage is present. A power supply board will also have lower voltages which will not be detected by the non-contact voltage detector.
        As far as damaging a meter, it depends on the capabilities of the meter and what you are trying to measure.
        Checking for faulty components is best done by measuring resistance, capacitance, voltage, or current. These are all things that a non-contact voltage detector will not do.
        • darkweezil
          • Dec 2013
          • 10
          I understand.
          I have another Samsung LN40A550P3FXZA that I am trying to sort out. The guy told me that the high voltage side is usually to blame for the problems that I am experiencing.
          Just thought I would find a good way to check the board for proper power output.
          I wish I could find a schematic to tell exactly what voltages I should be getting from each point.
          • T30M31
            • Feb 2014
            • 58
            Some of the boards will have the voltages listed in the silkscreen. You can also get a general idea of what a voltage might be by the capacitor ratings. A capacitor rated at 450 volts will have less than 450 and probably in the range of 300-400 volts.
            If you measure the voltage across the capacitors or after it has been rectified and filtered it will be DC and you meter will work fine as long as you have the voltage range set higher that what you are measuring.
            For help on troubleshooting the Samsung TV you would probably be better off to start a new thread with the Title listing the TV make, model, and problem description. In the message include a more detailed description of the problem along with good clear pictures of the back inside of the set showing all of the boards and pictures of each individual board. There are a lot of very knowledgeable people on here that will probably be able to help you.
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
              Now...
              06-09-2024, 10:57 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
