did anyone had same issue before
  • bboykes
    • Dec 2013
    • 28
    • england
    hello everyone i got 37 technika lcd tv psu board is really loudly seems like electrical noise psu board is vestel 17pw20.1 i bought repair kit and put on board still same and i re solder all the caps on the board any help will be really
    appreciated no caps bulged on the board
    Re: did anyone had same issue before
    Yes, I've had this before due to poor PFC circuit fault. It will get worse as the PFC circuit drifts further out.
    • bboykes
      • Dec 2013
      • 28
      • england
      did you just replace psu than or repaird bud
        I replaced the PSU because I had a spare one lying around.
        • bboykes
          • Dec 2013
          • 28
          • england
          i have to replace i need to have a look what i got cheers mate
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • notallbad
            TCL 55RP620K power board issue
            by notallbad
            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
            0% p_dim at 1.65v and a_dim at 1v
            50% p_dim at 3.3v and a_dim at 1.65v
            100% p_dim at 3.3v and a_dim at 2.88v
            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
            Leds are 2 rows of 15 6v leds.
            On inspection of the power board found diode MBR3200 shorted so replaced with...
            07-12-2025, 05:45 AM
          • eclectric
            Sony Bravia KDL-70W850B T-CON board / software update issue
            by eclectric
            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
            05-23-2022, 01:25 AM
