    • Jul 2011
    • 6040
    After all of that I managed to get the switching power supply working properly again I still have to replace the output capacitors but did not want to do this before I made sure that the daughter board to the main board was working properly or not now that I know that it is working properly I will now replace the output capacitors so I have a power supply for one of my battery testing machine
    I am not sure if this switching power supply is medical grade switching power supply it the same company that I have the switching power supply that are but they have a lot better board quality than this one does and the other one does not have a daughter board in it and it does not say Panasonic on the enclosure but the layout is very similar inside of the board so who knows
    • 31051
    33uf would be my move.
    or 47 - depends on what it seems to be for.
      • Jul 2011
      • 6040
      I tried this a couple of times on switching power supplies and things did go very well either it would turn on or it wined really bad so I decided to go that route because of the results that I have seen before
      • CapLeaker
        Leaking Member
        • 8186
        33uf isn’t that common but you should have 47uf in stock, so put either of these in.
        • redwire
          • 3910
          You'd have to know what the two caps are doing, if their value is critical or not. Going from 27->33uF is reasonable.
          If the cap(s) are part of the SMPS IC power then you'd get a delayed start-up, a few more seconds can get added before the PSU starts up with using bigger parts. I'll go from 22->33uF because they take the ripple current better which is one reason the little caps fail.
          What model is this PSU, post pics if it's a crazy Japanese SMPS with Sanken and discrete parts or does it use an IC?
          Sometimes manufacturers will use an oddball value like 27uF because they got a good deal on them.
            • 31051
            27uf +20% for tolerance is 32.4uf
            just saying
              • Jul 2011
              • 6040
              33uf isn't that common but you should have 47uf in stock, so put either of these in.
              You are right that it not a common value but it is common in servo drive boards so that is the reason I plenty of them of them if this board quality was not so bad as far as the traces lifting off of the board I would probably would try it and see if it complains about the higher UF value
              I also have 39uf @ 50 volts for the same reason they are common in servo drives as well and I have plenty of them as well
              I have plenty of the 4.7uf @ 50 volts because some of switching power supplies have this value as well
              The main reason I used the two values is because I have them in my capacitor parts bin and because there was p
              l of room on the daughter board and because of the way that it was attached to the main board it gave you plenty of room to put them in there that way
                • Jul 2011
                • 6040
                just saying
                Yes real close to the high limit of the range and like you said it should work with no problem I even consider just using 22uf @ 50 volt ones but this is in the lower range limit but like you I would prefer to go in the higher range limit and not go to the lower range limit
                  • Jul 2011
                  • 6040
                  Here are the pictures of the switching power supply in question
                  • redwire
                    • 3910
                    I don't see a main PWM control IC in there, but the two 27uF caps might be for the driver stage of a 1/2 bridge, they are to keep imbalance or maybe average current reasonable. They see action when the PSU is heavily loaded.
                    Never seen a Marcon primary cap before 180uF 400V.
                      • 31051
                      marcon are complete crap, i just replaced over 90 of them in a scope.
                      • redwire
                        • 3910
                        I know the Marcon paper-in-oil HV caps are crap, used in Leader oscilloscopes. No idea about their electrolytics though, if they are any good. It is an old Japanese brand.
                        • CapLeaker
                          Leaking Member
                          • 8186
                          Interesting… I am working on a Motorola XPR8300 UHF with intermittent power up. Coincidentally I am in that PSU. Man that thing had a hard life. It lived for like 16 years on top of a commercial wind mill. You wouldn’t believe how much dirt there is in that thing. The fan in the PSU has an open too…
                          I can’t for my pity lil life not figure out where this thick oil like substance (almost like fluid film or rust check undercoat) come from. It definitely got sucked in and 99% IPA doesn’t really clean it off either. Had to put it into the ultrasonic cleaner for 30 mins and that did the trick.
                            • 31051
                            maybe somebody was blasting 3-in-one onto some moving parts in the general vicinity?
                            • redwire
                              • 3910
                              Must be ectoplasm
                              I know I'm in trouble if dishsoap or IPA does nothing, it's not oil then. Then it's acetone or worse I use.
                              Could be some farm spray, they use pesticides etc. or a windmill spray cleaning solvent or something.
                                • 31051
                                does it look like a liquid or just feel like one?
                                i know the shit they spray out of chemtrail planes feels like powdered teflon because it collects in electrostatic air filters!!!
                                • redwire
                                  • 3910
                                  Maybe the windmill had a tranny leak?
                                    • 31051
                                    wouldnt something like that be at the lowest point for weight reasons?
                                    • redwire
                                      • 3910
                                      Wind generators have the prop go into the gearbox right away, they are top heavy.
                                      But I'm not sure what the windmill is all about. Prairies in Canada I only see small ones pumping well water on farms, they are just open-frame steel trusses. No room or radio inside.
                                      It's a prop to right-angle pinion gear then shaft goes down to the ground.
                                      It would be good to know more about the slime on the PC board. I have seen coal dust, cigarette tar and nicotine, grease from a restaurant cooking grill on boards.
                                      Ones from bars/lounges are the worst, it's like booze liqueur goo and girl perfume on the boards lol. I ended up using Fantastik spray on them.
                                      I found ultrasonic cleaning very hard on electronics, it etches solder and busts crystals or IC bonding wires if you are aggressive with it, compared to using the right solvent.
                                      Unless something else leaked and took the piss.
                                        • 31051
                                        the worst is vaporised cola,
                                        some arcade gear will suck spilled drinks into the fans and blast it into the pc unit!!
                                        coin mechanisms are protected from drinks being poured into them with conformal coating, but the motherboards are vulnerable!
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
