I found SI 3120C is this the replacement component for SK 3120C? Also, if the regulator has an input v rating does that mean it has to take in that number of volts or that it cannot exceed that number of volts on intake?
Regulator SK3120C
Tags: None
Re: Regulator SK3120C
There is the limit how much the input voltage can be before the breakdown voltage happen. it is in the spec. There is also required minimum input to produced the required output voltage, the data sheet will have all those information.Never stop learning
by sam_sam_samI bought one recently but this is the first weekend that I did not have work Saturday morning or the sun did not want to cooperate with me but today it is coordinating with me and I run a very simple test on a 12 volt battery pack and it stop charging ar 14.4 volts
Here is the website link where I bought it from
https://www.ebay.com/itm/395434828814
I ran this test with a new 12 volt solar panel that has a no load voltage of 19.0 and an output current of 9.1 amps
I do not remember the starting voltage but the charging amps was 1.4 amps
...09-14-2025, 11:49 AM -
by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
by MisterAILHi everyone,
Brought a non functionnal PS5. Apparently only a bad PSU...
No beep, nothing.
After some tests i found this :
- PSU is fine (12 volts stable)
- 12 volts line is shorted
- DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
- By the way, nothing change. No signal, no power, no beep.
Mesuring all rails with my workbench psu (12 volts input)
- 0.00 amp drawing
- 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...5 Photos -
by McfeetroyGood day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
- Loading...
