component identification of welding machine
  • wolf1976
    • Oct 2023
    • 108
    • Ελλάδα
    hi
    in a bit7000 awelco weld machine it has damaged an ic 16 pin that you can see on the bottom fotos
    i have take this foto with my mobile on the display of digital microscope
    can anybody to understand what component is ?
    • 31009
    very clever - magnifying the dirt.
    clean it with alcahol and take a fresh picture
    • wolf1976
      • Oct 2023
      • 108
      • Ελλάδα
      i will do it thanks
      • wolf1976
        • Oct 2023
        • 108
        • Ελλάδα
        sir after the useful advice
        writes
        above and in the right corner 324
        and on the bottom GZGY924
        i think must be lm 324 because the bottom number i cannot find anywhere
        do you agree ?
        • lotas
          • Jan 2016
          • 4579
          • Russia
          LM324DT
          And there are not 16 contacts, but 14
          • wolf1976
            • Oct 2023
            • 108
            • Ελλάδα
            yes sir you have right and thanks
            • wolf1976
              I'm looking for a selective TIG-MMA switch on welding machine
              by wolf1976
              hi
              on the bellow pictures i have include the upper and the bottom area of this switch
              the machine had fallen and this switch is break can you suggest me a suitable switch to change it ?
              i dont know if this switch is the only problem because the welding is open normal the green led is light but it welds with interruptions
              and when i turn it on i measure the voltage and its only 6 volt i dont know if this is right
              thanks on advance...
              07-08-2024, 01:49 AM
            • mojos911
              Fisher and Paykel 10 kg top-load washing machine LED identification
              by mojos911
              I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
              If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
              01-17-2025, 06:54 PM
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
            • rayane
              wiring diagram for electrofusion welding machine elofit nupigeco
              by rayane
              please i need shematics of electrical wiring diagram for electrofusion welding machine elofit nupigeco , thank u .
              06-26-2022, 06:29 AM
            • CG2
              Janome DC3050 Sewing Machine Pedal Resistance
              by CG2
              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
              04-14-2023, 07:53 AM
