I'm looking for a selective TIG-MMA switch on welding machine
  • wolf1976
    • Oct 2023
    • 113
    • Ελλάδα
    hi
    on the bellow pictures i have include the upper and the bottom area of this switch
    the machine had fallen and this switch is break can you suggest me a suitable switch to change it ?
    i dont know if this switch is the only problem because the welding is open normal the green led is light but it welds with interruptions
    and when i turn it on i measure the voltage and its only 6 volt i dont know if this is right
    thanks on advance
    • 31255
    shouldnt be hard to find another,
    you need more info though.
    spacing between the pins,
    type of action - left/right or does it also stop in the middle,
    where is the top section? did it have a screw thread - questions like that.
    • wolf1976
      • Oct 2023
      • 113
      • Ελλάδα
      thanks for the answer
      it has only left right without stop on middle
      it has screw thread
      i havent meter for measure the distance unfortunately
      i want to choose the right switch as about the contacts because i am afraid if the switch is not suitable maby i will cause a furthermore damage to the device
        • 31255
        well it's called an SPDT toggle switch when your searching.
        the letters stand for "Single Pole Dual Touch" as in single contact going 2 ways
        • wolf1976
          • Oct 2023
          • 113
          • Ελλάδα
          thanks a lot sir
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • Natob82
            Micro Momentary Push Switch?
            by Natob82
            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
            12-21-2022, 05:22 AM
          • grimacelord
            NEC TurboExpress On/Off Power Switch Replacement Help
            by grimacelord
            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
            11-09-2023, 09:49 AM
          • SluggerB
            Help making a switch work the opposite way with a relay
            by SluggerB
            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
            02-07-2025, 07:57 PM
          • Wolf1977
            question about diode of an old welding machine
            by Wolf1977
            hi in an old welding machine i have the power diodes you can see from the fotos
            these diodes the most of them are damaged
            do anybody know if there is possibiliti to change them ;
            the one side is easu to dissasemply and connected the pins the other side is connected in a material on metalic plate likes as seal
            does anybody has change diode like in mine case ;...
            10-23-2023, 01:24 PM
