Testing fuses in circuit: With power and no power
+ More Options
Posts
  • kisk
    Computer Tech
    • Jan 2014
    • 78
    I have a surface mounted fuse that I have tested and it seems open (OL on my DMM), however when I have the device powered on (LCD monitor) the resistance shows 0.0. What is the idea behind this and why am I getting this reading if the fuse is blown? Why wouldn't it be OL with both readings?
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Testing fuses in circuit: With power and no power
    Your second way is not considered as correct practice about making a correct measurement.
    Therefore any answer on that would be plain guesswork.
    • kisk
      Computer Tech
      • Jan 2014
      • 78
      Thank you. So always test fuses either out of circuit, or in circuit with no (and discharged) power?
      Another fuse question: I was testing this fuse with the continuity setting on my DMM and it showed OL. When I switch to ohms (auto) the fuse reading jumps up about 30 M-ohms each poll and the reading evens out around 1.6 k-ohms. Can I assume there is a short somewhere or are some circuits designed like this? Would I have to desolder the fuse to get a true reading?
      BTW, I just got this new DMM which I'm using.
      • tron
        • Apr 2009
        • 47
        No, you do not have to extract
        the fuse from the circuit board,
        to get a true(shorted) reading
          When the circuit is energised, you are basically putting high voltage across meter terminals expecting around 200mV. This is the same reason behind getting negative resistance readings sometimes on powered circuits.
          • kisk
            Computer Tech
            • Jan 2014
            • 78
            This is what I expected, but why is the end-to-end point of the fuse reading 1.6k Ohms. This is what I would expect reading off of a resistor, not a fuse. ?
            , and thanks for the info tom66.
              You are reading the circuit resistance, for example the power filter cap may have bleeder resistor (for example, 1K) across the cap (+ leg and the - (gnd) leg of the cap) or other branch circuits resistance that power supply is feeding before the fuse, then the fuse is connected to the positive leg of the cap, another end of the fuse will go to the load which has resistance (lets say 1K). So when the fuse is open, you are reading the resistance of the circuit, 2K.
              Just draw out the diagram then you see why you are reading resistance.
              • Radio Fox
                • Jan 2010
                • 281
                For future reference, never use the continuity or resistance (Ohms) setting on your meter to probe a circuit while it's powered up. You could damage your meter.
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • Longbow
                  • Jun 2011
                  • 623
                  Well that might have been true back in the days of the Simpson 260. Lots of meters got smoked when trying to measure the "resistance" of a battery. These days electronic meters will self protect because even the best of us occasionally forget to change functions.
                  As far as measuring a fuse - this is extremely easy. 1). with the power off, the fuse (if it IS a fuse) will measure nearly ZERO ohms. Meter on ohms function. 2). With the power on, you will measure the same voltage at either end of the fuse. (volts function). Pick one. Neither method requires the part to be removed.
                  SMD fuses do exist, but the pcb will usually be marked "F01" or similar. There are also fuse resistors, which are low value resistors and not fuses.
                  Since your fuse is open, the next step is to measure the resistance (power off) to ground to test for possible short circuits that might have caused the fuse to blow. Schematics?
                  Is it plugged in?
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • beetle1303
                    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                    by beetle1303
                    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                    01-13-2025, 08:49 PM
                  • Powderfanupnorf
                    Dell AL440LX power on switch circuit help required
                    by Powderfanupnorf
                    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                    06-24-2024, 01:24 PM
