HER303 substitute?
  • dcapper
    • Dec 2013
    • 496
    HER303 substitute?
    My power supply in my RCA TV blew an HER303 diode. NTE cross is NTE588. I through an NTE587 in for testing and the tv worked right away. I don't want to leave it that way since the NTE587 is only 1 amp and the NTE588 is 3 amp. I found a diode out of an old pc power supply that looks like it would work. Its number is 1.5KE350A. NTE cross is NTE4994. I also have an 1N5406. NTE cross is NTE5806. It's the same specs but a standard recovery not ultra fast. Any ideas if any of these diodes can be used or should I just order a 303 from Digikey?
    Re: HER303 substitute?
    Standard recovery will get hot since it does not turn off fast enough, use the correct one as original or with higher voltage/current rating one with fast recovery.
    • dcapper
      • Dec 2013
      • 496
      Thanks Bud. I'll order what I need then.
        master hoarder
        • May 2008
        • 12170
        UG4D should be a good replacement.
        MUR420 is another alternative. It's actually a little better in terms of current capability - 4 Amps vs 3 Apms for the HER303.
        Depending on which manufacturer you get it from, though, you may or may not get lower reverse recovery time (so always check data sheet upfront). For example, this one from Mouser has both lower reverse recovery time and is rated for 4 Amps at 80C, which is good:
        http://www.mouser.com/search/Product...wrlOf4Ew%3D%3D
        But this one from Digikey is from a different manufacturer and not as good as the one above (though, in a pinch, it would probably work too)
        http://www.digikey.com/product-detai...SCT-ND/2512855
        And here's one from ON Semi on Digikey that is good as well:
        http://www.digikey.com/product-detai...GOS-ND/1482828
        • matyka
          CSRS545 Diode Substitute? Help
          by matyka
          Hello, I have a power supply and I found a shorter diode CSRS545 , any substitute to buy?
          03-04-2023, 11:56 AM
        • volinakis
          Chromebook recovery failed - how to fix it
          by volinakis
          So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
          Finally I found a site where they suggested to try with an older image and ... it worked!
          What I did:
          - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
          09-18-2023, 03:26 PM
        • FZG
          Looking for specific recovery diode equivalent
          by FZG
          Hi! I hope someone can help me. I am looking to replace two types of fast recovery diodes in a Sony BVM1410PM monitor power supply .
          The parts in question are "ESAC25-04C" and "ESAC25-04N" (both 400V 10A in different configurations).
          Here is a datasheet:
          https://pdf1.alldatasheet.com/datash...SAC25-04C.html
          The problem is, I can not find these parts for sale anywhere. So I wonder, does anybody know of suitable equivalent parts?
          04-23-2023, 06:17 AM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
