CSRS545 Diode Substitute? Help
  • matyka
    • Jan 2015
    • 179
    • Uk
    Hello, I have a power supply and I found a shorter diode CSRS545 , any substitute to buy?
  • petehall347
    • Jan 2015
    • 4448
    Re: CSRS545 Diode Substitute? Help
    did you mean https://www.alldatasheet.com/datashe...TC/CRS545.html
    • matyka
      • Jan 2015
      • 179
      • Uk
      Yes, I am not good with substitute and I don't want to solder something else to pop .
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        Mitsubishi CNC switching power supply board dead / relay board bad diode failure
        I was working on this CNC machine today found no keyboard functioning no control relay powering on
        The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
        Found shorted diodes on main controller relays there are 3 of them that...
        01-07-2023, 05:43 PM
      • Driver8
        LG EAY57681601 power supply diode
        by Driver8
        This is on the power supply/backlight inverter board EAY57681601 for LG 47LH40-UA television. The supply failed when commanded from standby to run, taking out the main fuse. I'm trying to identify diode D601 in the inverter section where the package was blown apart and the markings are gone. Q601 and Q602 will need to be replaced also. If anyone can point me to a schematic that would be most helpful. Also would like to hear if anyone has repaired this type of failure before.
        09-01-2024, 05:58 PM
        07-01-2024, 06:34 AM
