Cap ESR reading is it right?
  • notallbad
    • Oct 2012
    • 1190
    The cap is an ELNA LP5 35V 6800 uF with a reading, out of circuit, of 0.01ohm. The meter is an ESR-2501A.
    The capacitance is 6270 uF using an Iso-Tech 9023.
    Does this sound about right for this size cap?
  • snipersquad100
    • Nov 2013
    • 297
    • uk
    Re: Cap ESR reading is it right?
    this might help
    • notallbad
      • Oct 2012
      • 1190
      Thanks, so looks like the ESR is likely to be ok.
      • snipersquad100
        • Nov 2013
        • 297
        • uk
        Looks good to me
        • SuperAman
          PS5 HDMI port diode reading?
          by SuperAman
          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
          02-03-2024, 10:16 PM
        • Fuzzy Fix
          0.00 ESR reading on a capacitor
          by Fuzzy Fix
          Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
          I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
          Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
          07-26-2024, 12:05 AM
        • kalilinux25
          no 3v and 5v section voltage reading
          by kalilinux25
          Hi my board is HUSK MB 11309-248.4TU05.021
          The board is plugg and consuming 13 milliamp
          measuring the 3v coil no reading and the 5v coil no reading
          Ive measure the pins in PU4103 ( RT8223M)
          1- NO READING
          2- NO READING
          3- 4.4V
          4-NO READING
          5- NO RADING
          6- NO RADING
          7-3.3V
          8- 5V
          9-19V
          10- NO RADING
          11-3.3V
          12- 3V
          13-
          14
          15
          16-4.4V
          17-3.3V
          18- NO READ
          19-5V
          20- NO READING
          21-2V
          22-2V
          23-NO READING
          24- 5V
          01-27-2020, 03:01 AM
        • Thoa
          Dell Latitude 5440 IDB40 LA-M401P reading the Bios-WSON8 UC2
          by Thoa
          Hello Community...
          I am totaly disappointed, cause i bought a used Dell Latitude 5440 with a cracked display. I ve spend another 50 Euros for the new screen and it does his job very well. Then I reallized that a Bios-Passwort is set. First I bought the CH341A black edition with the clamp and was confidence, that it will do its job, realizing that this does not work. So I decided to buy a pogo-pin-tool to read the UC2 first of all (nothing tried on UC6 Yet). The outcome was very random when reading the WSON 8x6, so I decided to buy the XGecu T48, but it is the same. No reliable data....
          08-12-2025, 04:05 PM
        • camisao
          APC Smart-UPS 3000 XL (SUA3000XLI) not reading voltages well
          by camisao
          Hello there,
          I have a issue with a tower UPS 3000XL with also an external battery tower that has almost new batteries and very little use.
          A week ago it started entering boost mode because the read line voltage was below 210VAC, when it was in fact near 225 VAC.
          The battery voltage was also low (48 or 49), when in fact the batteries are fully charged to 55.1 VDC.
          I opened it up up, cleaned and tried a reset.
          I updated lower transfer voltage to 196 with apctest and then used the serial port to adjust the configuration with a terminal in Prog mode...
          04-03-2025, 07:12 AM
