need som help iding a IC
  • yonu
    • Nov 2007
    • 138
    Like the title says I am hoping someone can help me I'd a ic vI have had no luck on Google I am attaching a pic.
    It is labels CTS7643
    Thanks,
    Yonu
    Re: need som help iding a IC
    That is the resistor network made by CTS, 330 ohms
    • ReverendJones
      Resurgam
      • May 2010
      • 49
      Data sheet: http://datasheet.octopart.com/760-3-...eet-119313.pdf
      Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
      • mariushm
        • May 2011
        • 3799
        Like budm says, the IC is basically a bunch of resistors.
        The most common arrangements are these:
        Yours is probably the first model. But you can use a multimeter to check the resistance between pins.
        Here's some examples of what you could probably use:
        http://www.newark.com/bourns/4116r-1...=4116R-1-331LF
        http://www.newark.com/bourns/4114r-1...=4114R-1-331LF
        If there's more pins you can probably just cut/bend the extra pins to fit in the socket.
        ps. I see ReverendJones found the datasheet.
        • yonu
          • Nov 2007
          • 138
          Thanks all I didn't even know I had them I found them digging through my parts drawer must have got them in a batch of stuff I bought at the last HAM swap fest.
          Thanks,
          Yonu
          • Andriy Andrusyk
            How to Identify My GPU When CPU-Z and Physical Labels Disagree?
            by Andriy Andrusyk
            I recently bought a used GPU that was advertised as an MSI GeForce GTX 1080 Ti. The backplate label also identifies it as a GTX 1080 Ti, and the label looks untampered.
            However, when I run CPU-Z, it detects the GPU as a Radeon RX 480.
            I inspected the PCB and found a second label near the gold connector reading: V341 VER:1.1 From what I've found online, V341 PCBs are typically used for Radeon RX 480, while GTX 1080 Ti cards usually use a V360 PCB.
            Is it possible the card was BIOS-modded or relabeled? What's the most reliable way to verify the actual GPU model I have?
            05-13-2025, 01:32 PM
          • Prott
            Intel NUC 7i7 - attaching m.2 drive causes no picture output
            by Prott
            I am getting a bit desperate with this one and would appreciate any help.
            I came across a NUC 7i7 that initially had a short on the USB header "rail" (one of the decoupling capacitors). But, besides that, it displays a weird behaviour - if I don't attach anything to the m.2 slot it works great (boots into windows, etc.). However once I plug in an m.2 drive the computer won't display anything on the screen.
            There's no picture, but the computer is still working (I can turn on/off numlock, etc.). This behaviour remains the same even if I disable...
            05-19-2024, 06:37 AM
          • Stefo
            Need Help IDing Diodes
            by Stefo
            can anyone help identifying these three diodes please? ive tried googling for 2 days with no success! They are from a Japanese audio board for a slot machine built my guess around 2000. They seem to have spec'd Japanese manufacturers for everything else. the approx dimensions are on the photos.
            Curious right leaning tick mark on D1 & D2, backwards Z? on D3
            Thanks https://www.badcaps.net/forum/images/smilies/dunno.gif...
            01-25-2023, 10:37 PM
          • NConstantinou
            Macbook pro 13" mid 2010 a1278
            by NConstantinou
            Daer all
            i need bios but i am not 100% sure about model
            i beleive is a1278. No labels on board.
            I am attaching bios file.
            Laptop does not power on and i need bios file
            thanks...
            11-16-2022, 09:19 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
