Two sla batterys don't want to go over 12.3 volts
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    I got these two sla batterys from a ups that was left on and drained to 0 volts.
    I have got them to charge to around 12.3 volts but when I try to go to 13.8 they start to get very warm about 30 to 40 c at 1 amp.
    I have been charging them at 400ma and they still get warm and voltage does not seem to increase should I just give up?
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: Two sla batterys don't want to go over 12.3 volts
    try using desulphator
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Give up.
      If you can't get the SLA battery to 2*(number of cells) OCV, likely there's a shorted cell in the pack, and no desulfater will fix that.
      I ran across a bunch of these shorted cell packs, if you can still use the pack with a lower voltage, great, but likely it's time for the trash.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        dendrites.
        they are done.
        had 2 nearly new mk wheelchair batteries that acted like that.they were left at 0v 6 months.normally i can bring them around but they were essentially shorted.albeit high resistance shorts.
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Ok I am going to try discharging and recharging a few times and see if that helps.
          Otherwise I can just use them for another purpose that won't try charging to 13.5 - 13.8 volts.
          My pc
          • japlytic
            • Oct 2005
            • 2086
            As far as I know, there are no desulphators that work on SLA batteries - the only ones I've seen work on flooded lead-acid batteries.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              6-cell SLA cells should easily hit 14+ volts at full charge. Remember to let the battery sit for a while (few hours) before measuring voltage, if a SLA pack won't stay above 13 volts, that pack is shorted. Likely a battery pack that has a shorted cell also will have high self-discharge and probably should head to the recycle bin.
              I was about to say discarded but please don't discard lead... Recycle it.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Yea 1 battery does have a shorted cell running my fingers along the side one cell on one battery gets hot. I'll see if the other has same fault.
                My pc
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Actually the hot cells are the ones that are still OK, cold ones tend to be the shorted ones...
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Yep.
                    Also, I have heard that you can discharge a capacitor into the capacitor, in hopes that the dendrite will melt/vaporize. However, there is only a small chance that it will work, AND, it has a chance of growing back again.
                    I say just give up on them. Not worth the time, unless you want to try...
                    Muh-soggy-knee
                    • infringer
                      Badcaps Member
                      • Sep 2009
                      • 244
                      • United Frickin States
                      yes flooded lead acid is known to be repaired with epson salt finely crushed mixed and cooked to 160° F but their is a science behind it it has to be x parts water to x parts epson salt and then it has to be recharged on a slow trickle for the battery to undergo the chemical reaction that is supposed to properly take place.
                      Anyhow I know nothing of SLA based batteries I guess it is a new interesting thing I'll have to look into dunno why but batteries have been of interest to me lately.
                      Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Word from the wise, again: toss the SLA batteries that don't reach full expected voltage, unless you can deal (both charge and use) with the lower voltage...
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          Yea I have given up on them.
                          My pc
                          • MisterAIL
                            PS5 digital / No Power / No Beep / Good power supply
                            by MisterAIL
                            Brought a non functionnal PS5. Apparently only a bad PSU...
                            No beep, nothing.
                            After some tests i found this :
                            - PSU is fine (12 volts stable)
                            - 12 volts line is shorted
                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                            - By the way, nothing change. No signal, no power, no beep.
                            Mesuring all rails with my workbench psu (12 volts input)
                            - 0.00 amp drawing
                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                            03-12-2024, 03:24 PM
                          • Loretto
                            Samsung SMPS BN44-00339A
                            by Loretto
                            this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                            I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                            I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                            I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                            03-29-2025, 08:30 AM
                          • Loretto
                            by Loretto
                            03-28-2025, 10:28 AM
                          • BTubbs200
                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                            by BTubbs200
                            Dell Latitude 5420 P137G
                            Board: LA-K491P REV A01
                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                            Board seems to have no shorts, all power rails are fine and show high resistance.
                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                            01-24-2025, 08:15 PM
                            MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                            I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                            I open it up to find non brands name capacitors in it
                            I am not sure how this switching power supply is set up
                            Could someone please explain how this power supply works
                            Here is the capacitor ESR results
                            (1) 47uf@50 volts 0.46
                            (2) 47uf@50 volts 0.45
                            New 47uf@50 volts 0.35
                            (1) 100uf@25 volts 0.34
                            (2) 100uf@25 volts 0.35
                            New 120uf@50 volts 0.08
                            (1) 220@25 volts 0.13...
                            10-21-2018, 10:02 AM
