Are these two components interchangeable?
  • gintama
    • Sep 2007
    • 59
    I have an old PCI video card that I keep around for testing - it still works OK except there is no Green output. This makes it extremely difficult to read things in BIOS screens, etc. So I figured I would do a little poking around and see if I could figure out what's causing the problem.
    Lo and behold, the green output pin is shorted to ground. I started tracing the circuit back towards the GPU chip (a Creative Riva TNT, in case you're wondering), and didn't get far before I found that the tiny SOT-23 MOSFET on the green output is fried (Gate shorted to Source):
    I believe this may be an AO3407 from Alpha & Omega Semiconductor (datasheet here).
    Looking though my junk box, I have a dead ATi PCI-e card of some sort, which has some MOSFETs of the same size labelled RKS 46, which I believe might be the ROHM RK7002A (datasheet here).
    I need some help figuring out whether this is a suitable replacement part... Looking at the schematics, it stands out that the integrated diodes are facing different directions, but I assume that doesn't change the outward function of the chip, otherwise the pins would no longer be in the same configuration?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Are these two components interchangeable?
    I cant open those 2 links, MalwareBytes blocks them.
    As long as the 2 parts are of the same polarity, like N-Channel and the pin out is the same which it always is for that package as far as I have seen, It will be ok to try.
    EXTRA: Ok, I closed MalwareBytes and had a look at the 2 links, nothing bad happened. Those 2 MOSFETs are opposite polarities or complements of each other.
    • gintama
      • Sep 2007
      • 59
      Thanks for looking, I guess I'll keep hunting...
      On the other hand, is it possible the mosfets aren't necessary? Another dead video card I pulled out has the same-ish layout to the VGA header and has the solder points for mosfets, but they're unpopulated...
      • rievax_60
        • May 2012
        • 897
        • australia
        Its possible they are there to protect the outputs from high voltage spikes.
        It was a real problem when plugging in a CRT monitor because of the possible static build up on the screen.
        Try it with the MOSFET removed.
        I used to solder 5.6v zenners from the outputs to ground on cards that I would use alot for testing CRT monitors.
        • gintama
          • Sep 2007
          • 59
          Well... The site above also lists "A7p" as a switching diode, so I may not have even identified the part properly... I still haven't found any confirmation of who the manufacturer might be, but as the card is from 1998 that's not completely surprising. I guess I'll try removing this part that acts differently from the other ones and see what happens.
          • rievax_60
            • May 2012
            • 897
            • australia
            That would make sense. Each middle pin looks like it connects to a signal path. I would be curious to know if all the left pins all connect to the same rail. And if all of the right pins all connect to another rail.
            • gintama
              • Sep 2007
              • 59
              Looking at it from the orientation in the photo, the left pins all lead to ground. The right pins are also tied together for each group (R/G/B, and then Vsync/Hsync/?), R=~20 Ohms.
              • rievax_60
                • May 2012
                • 897
                • australia
                Im suspecting its something like this but protecting outputs insted of inputs,
                http://www.radio-electronics.com/inf...guidelines.php
                • gintama
                  • Sep 2007
                  • 59
                  That site doesn't respond for me, but I think I get the usage here if it is a diode - basically, voltage goes out OK but is shunted to ground if it's coming in from whatever's plugged in?
                  At any rate, I removed the part and nothing changed. Guess I'll have to live with it, or find a scrap PCIe card somewhere. Thanks again for your input rievax_60.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Could be a BAV99 - see here
                    https://cdn.badcaps-static.com/pdfs/...ddbe71062e.pdf
                      This is the typical way the VGA and DVI inputs are protected. The Monitor will function if they are removed, just will be no protection.
                      • gintama
                        • Sep 2007
                        • 59
                        @selldoor: That's what I was referring to in post #5. I fiddled around with my dmm's diode detection setting trying to come up with a way discern a diode vs a mosfet and couldn't see any real pattern, which is why I gave up and just removed it.
                        @budm: Hello again, and thanks for the link - the diagram looks very similar to this PCB's layout. There are very few parts between the GPU chip and the output pin: the diode(?), a few small caps, and a resistor... I guess I could try replacing or removing the other ones as well.
