DVM Dimi ?
  • barry wilkins
    • Aug 2009
    • 172
    DVM Dimi ?
    I bought this meter abroad as I needed one in a hurry it was not very expensive ,and has lots of functions.The instructions were not in English ,but it served its purpose ,I had noticed a battery symbol on the display but did not realize exactly what it meant.
    The other day I used it ,and it was reading about twice what it should of ?
    So I replaced the PP3 battery this fixed it ,when I checked the battery I had taken out it read 7.8 volts ,so I put it back ,when I checked it under load it was 3.5 volts.
    So it goes to show what effect the internal resistance (esr) has when you actually put a battery to use.
    I knew about the internal resistance of a cell from my training many years ago,but I did not know it was more complicated than I was taught. It is the sum of a number of resistances which makes it quite complex . This explains why on a vehicle battery (lead acid) it has voltage , amp hours ,and it states a time (normally 20 Hours) ,which I understand is the correct way to check the actual capacity of the battery.
    Barry Wilkins
  • mkdj
    by mkdj
    Mark and model: ASUS X571
    Tests already made:
    - I have removed...
    07-14-2025, 09:16 AM
  • techfreak9356
    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
    by techfreak9356
    09-14-2023, 11:10 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • ferah831208
    by ferah831208
    03-18-2025, 01:18 AM
  • huzo
    HP ELITE X2 1013 G3 weird battery issue
    by huzo
    Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
    01-31-2025, 12:09 AM
