Freezer questions
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Freezer questions
    A friend of mine has a comercial freezer.
    Now my questions are,
    therE is a switch with a r and a c
    And two themostats labeled the same.
    What is the purpose of having two.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • dj_ricoh
    • 2073
    • uk
    Re: Freezer questions
    i think because it got two motors with two independent sensors.
    two thermostats for two areas
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      It does have two compressers but they seem to be in parallel.
      My pc
        • Jul 2011
        • 6070
        Originally posted by joshnz
        It does have two compressors but they seem to be in parallel.
        See if it has two cap-tube or two Term o expansion valves or Automatic expansion valves if it dose then it might not be
        in parallel because of the fact that it has two thermostats labeled the same.
        The reason for having two thermostats is one on the top half of the commercial freeze can be set for one temperature and the bottom half set a different temperature
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          One thermostat has C and the other R.
          Also I want to know what the toggle switch that has R for on setting and C for the other.
          The reason i'm looking at this is it has a frost issue and one of the other compressors has been disabled because of a "issue".
          My pc
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            sounds more like a defrost timer or thermostat issue.
            i have seen the thermostat popped open where water leaked in.
            then the heater wont run.
            • ktmmotocross
              GB RTX2080 Super - crash on load > second switched 12V instability > what is purpose of this circuit?
              by ktmmotocross
              Hello.
              Have this GB 2080 Super that crash on load. When half load i see instability on one of two switched 12V rails. I dont know its purpose and dont have BV or Schema for this board.
              Can anybody explain me what is purpose of this two switched 12V lines?...
              10-03-2024, 12:22 AM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • electronx
              Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
              by electronx
              I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
              1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
              According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
              If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
              06-26-2025, 03:27 AM
            • irfan karatela
              MOSFET PURPOSE
              by irfan karatela
              I'm looking at the PS5 motherboard, and have come across 2 mosfets, I want to understand the purpose of the 2nd mosfet as the source is connected to GND and the drain is connected to 5v. wouldn't this short the 5v rail once the 2nd mosfets gate is enabled?
              Thanks...
              12-20-2024, 04:52 PM
            • UL161
              Need Help Identifying Parts on a crossover and a few other newbie questions
              by UL161
              Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
              1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
              2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
              09-29-2024, 03:17 PM
